BurntOut Occasional Visitor
Posted: Sat Mar 18, 2006 3:39 pm Post subject: HELP Someone Please!!! |
Wondering if anyone can help or shed some light on our situation.
My workmate has just bought a C310 streetpilot yesterday.
Now this morning in work we switched on it picked up our location as somewhere in LONDON (default apparently). So we went outside and started it up again this time running the start up sequence (that only runs once) and it actually got our position in NORTHERN IRELAND.
So all was working fine, now we were reading on various areas about updates etc and sending cards mem cards away etc, when we had read that you still had base maps with the card removed, so we took out the card (the unit was off), when we switched on it just said no mem card in and we couldnt go any further,
So we placed the mem card back in and turned unit on again, but its now back to showing us in LONDON, and we cant get it to show us in NORTHERN IRELAND.
Can anyone help at al!!!
Is there a way of geting the first-time startup sequence to work again.
Yes we are complete NOOBS to sat nav.
All help GREATLY appreciated!!!l |
Ericd Lifetime Member
Joined: Dec 23, 2005 Posts: 57 Location: Plymouth Area
Posted: Sat Mar 18, 2006 4:06 pm Post subject: |
Have you got a Streetpilot Manual, if so it tells you how to set a Home Location. If not go to http://www.garmin.com/support/userManual.jsp where you can download same in PDF format. In the meantime on your unit select My Locations and then select Set Home. Select Enter My Address, enter the address you want to set as Home using the onscreen keyboard, then select Save.
Hope this helps,
Ericd |
arammisch Occasional Visitor
Posted: Sat Mar 18, 2006 4:14 pm Post subject: |
Setting the home location will not change anything to the location displayed on the screen. It is always the last position with sat reception. Only in simultaion mode (gps switched off) you will be capable to change the actual location. But once you switch off and on your device your location will be the last position with sat reception.
To come back to the initialization sequence:
(1) With device swiched off, hold the back button and press the power button during some seconds. Some data is displayed.
(2) Press the back button for second screen. Press twice the selection wheel and you will get into the diagnostics menu.
(3) Select Non-Vol Info and confirm with selection wheel.
(4) Select Clear Non-Vol Memory
This will restart the initialization seqeunce. You will lose all favorites and POI.
Albert |
Posted: Sat Mar 18, 2006 5:44 pm Post subject: |
arammisch wrote: | Setting the home location will not change anything to the location displayed on the screen. It is always the last position with sat reception. Only in simultaion mode (gps switched off) you will be capable to change the actual location. But once you switch off and on your device your location will be the last position with sat reception.
Albert |
M8 its the c310 model touchscreen one, doesn't have the back buttons or selection wheel
Any other ideas |
Posted: Sat Mar 18, 2006 8:37 pm Post subject: |
SORTED:
Believe it or not we actually connected it to his car and drove and it started working straight away. WHAT TOTAL NOOBS
Thanx to all who replied!!!! |
MELennium Frequent Visitor
Joined: Sep 25, 2005 Posts: 337 Location: County Durham
Posted: Sat Mar 18, 2006 8:39 pm Post subject: |
Hi BurntOut
Have you tried a full reset. Click on picture below to show it enlarged.
_________________ TomTom Go 910 (3) v.6.522 Map Western Europe v.650 with useless TMC receiver
Ex. owner TomTom 910 (2) Returned Faulty
Ex. owner TomTom 910 (1) Returned Faulty
Ex. owner TomTom One v.5.420 Map UK v.605
Ex. owner Garmin i3 v.2.7 Map UK V.7 |
