Pocket GPS World :: View topic - Help with i3 navigation for a newbie please
richard5
PostPosted: Sat Mar 18, 2006 11:51 am    Post subject: Help with i3 navigation for a newbie please Reply with quote
This could be a stupid question, but go with me on this.
I have uploaded a couple of POI files successfully (1 is UK airports and the other is Football grounds).
I want to naviagte to say Manchester Airport from Essex so I would do the following
Where To -
Food Hotels & More
Custom Points
Airports
And it then comes up with a list of Airports, but the list only has airports within about a 60 mile radius of where I am?
It does the same with football grounds, only lists ones within a certain radius? (about 125 miles)
I have checked that the airport and football grounds are in the CSV files (which they are).
Even if I spell the name it still doesn't find it!
Am I doing something wrong, or just being very stupid (probably the later).
Thanks for any help
PaulB2005
PostPosted: Sat Mar 18, 2006 12:14 pm    Post subject: Reply with quote
Sadly it only lists the nearest 50 POI.
I can't think of a way round it if it won't find it through spelling....
richard5
PostPosted: Sat Mar 18, 2006 12:27 pm    Post subject: Reply with quote
Thats a bit pants then!
Oh well I'll just have to find the postcode's etc.
Thanks anyway
oddsock
PostPosted: Sat Mar 18, 2006 12:36 pm    Post subject: Reply with quote
There is a way around this but it requires you to have access to Yell, or Google,..First search for where you want to go eg( Manchester Airport) which should bring up a postcode M90 1QX ..then input that into your i3.
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
richard5
PostPosted: Sat Mar 18, 2006 12:46 pm    Post subject: Reply with quote
Thanks for that
So as long as I have the postcodes of where I want to go no problem, but if I don't i'm b***ered! Sad
north_country_boy
PostPosted: Sat Mar 18, 2006 12:51 pm    Post subject: Reply with quote
What about setting the i3 to navigate to Manchester, when you are say 50 miles away, try and find the airport on in POIs and it should take you right there.
richard5
PostPosted: Sat Mar 18, 2006 1:10 pm    Post subject: Reply with quote
Thats a good idea, thanks :D
richard5
PostPosted: Sat Mar 18, 2006 1:24 pm    Post subject: Reply with quote
Just had another thought, there are a lot of POIS's in the list that are not of intrest to me if i reduce my CSV file to 50 or less POI's will it show all of them?
Spaceliner
PostPosted: Sat Mar 18, 2006 1:57 pm    Post subject: Reply with quote
THERE IS A VERY EASY WAY TO DO THIS
Where to/ cities/ (search by name) Manchester/ Manchester airport/
alternatively (a more precise way):
Where to/ cities/ (search by name) Manchester/ Manchester/ find nearby/ food, hotels, and more/ transit/ air transportation/ pick a terminal etc
using this method you can find the 50 closest POIs if any type near any location.
hope this helps.
richard5
PostPosted: Sat Mar 18, 2006 3:10 pm    Post subject: Reply with quote
Thats perfect spaceliner,
Serach for the area you want then look for nearby POI's
works a treat
Thank you
