kevwright Occasional Visitor
Joined: 21/08/2003 20:57:49 Posts: 27 Location: United Kingdom
Posted: Thu Mar 16, 2006 1:30 pm Post subject: BT GPS with Dell X51v (WM5) |
Hi all,
Just got the dell, and it only allows me to set COM 7 or COM 8, and I can not get MM to allow me to set either of those, only choices are COM 1 through to BT UART on Com 5, none of those work of course.
Is this still a Tomtom hogging port issue, I thought by setting COM 7 as a hardware port in WM 5 was supposed to solve that?
Anyone know if it is possible to get MM PPC version to allow selection of COM 7 or 8?
Kev |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Sat Mar 18, 2006 6:44 pm Post subject: |
My memory map is running on COM8. In the Menu-GPS-Setup, a pull down box will show all of the COM ports available on your PPC. If you cannot see a port, it will be because the PPC is telling Memory Map that the port is not available. |
Posted: Sun Mar 19, 2006 12:00 am Post subject: |
Thanks, any idea how I make the PPC tell MM that there is a port 7 or 8?
Kev |
richardstephens Occasional Visitor
Posted: Tue Mar 21, 2006 2:58 pm Post subject: |
Memory-Map lists all ports (1-9) since version 4.4.0.
If you are a UK customer stuck with an older version, what you need to do is create a registry entry for the com port:
[HKEY_LOCAL_MACHINE\Drivers\Active\999]
"Name" = "COM8:"
However, this part of the registry is rebuilt by the system, so you may need to set it up each time you reset the device...
Memory-Map, Inc. |
