Mark76UK Occasional Visitor
Joined: 15/02/2003 10:37:52 Posts: 15 Location: United Kingdom
Posted: Thu Mar 16, 2006 4:10 am Post subject: New POI using Makeov.exe |
Hi Forum
I have searched forum and can't seem to find the answer to my problem;-
After successfully creating a ".ov2" and ".bmp" file using the latest Makeov.exe program (using CMD window) I have tried various ways to copy these to my PPC, the files are there in the map directory, but TT5 will not display them?
I can open the file in PoiEdit program and the data displays OK! (note that the poi file only includes 1 line of data)
TT5 knows the file is there because if I tried to create a POI Category of the same name it tells me the name already exists??
I have noticed that all the dowloaded POIs have an extra "setup" file to accompany the ".ov2" and ".bmp" files, should I have one of these?
Please help, what am I doing wrong?
Thanks, Mark 8O |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Mar 16, 2006 8:05 am Post subject: |
You only need the ov2 and bmp Files to display a POI.
Have you copied the Files to the Map Folder as Files or as a Folder?
How many POI categories have you added?
Currently there is a maximum of 39 you can add/use. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Fri Mar 17, 2006 12:30 am Post subject: |
Thanks for reply oldboy.
Yep I thinks thats the problem, I have 42 loaded!
The Gatso POIs takes up many files, is it possible to put all the files in 1 POI to limit the 39 restriction?
Thanks, Mark. |
Posted: Fri Mar 17, 2006 8:10 am Post subject: |
If you download the Consolidated Files the ov2 are reduced to 5.
They are Listed by Types and not Speed Zoned.;) _________________ Richard
