Pocket GPS World :: View topic - TomTom 5/Dell X51v PDA
Goto page 1, 2, 3  Next
bobbillett
PostPosted: Wed Mar 08, 2006 12:49 pm    Post subject: TomTom 5/Dell X51v PDA Reply with quote
Has anyone had any experience of getting TT5 to work on the X51v?
The software runs but the device will not see the cable GPS. TT are of little help and Dell advise that differences between 51 and 51v are mainly cosmetic, screen size, memory etc.
Am running Windows mobile 5, which has facility to set comms ports for the GPS receiver.
If the cable option is not viable, will it work with a Bluetooth GPS?
Any advice/ideas would be appreciated.
Regards
Bob
PostPosted: Wed Mar 08, 2006 2:28 pm    Post subject: Reply with quote
Bob, Welcome to the forum, in tomtom/ preferences/ gps status use the other cable NMEA device, set the BAUD speed to that which your GPS unit uses, then on the next page will be a port called ser??1?? (or something like this) select this and give it a try, this worked on an x50v that had WM2005 loaded, there is another post on here somewhere detailing a reg edit from last Dec (ish) have a search for x51v and it might come up - I am mobile at moment so its too slow to nav around the site on the phone - will find it later tonight if you are still struggling - Mike
peterc10
PostPosted: Wed Mar 08, 2006 2:51 pm    Post subject: Reply with quote
Also what version of TT5 are you using - you need to update to latest version (free from TT site) if you want to use it on WM2005.
Peter
HTC Sensation
Copilot for USA
bobbillett
PostPosted: Wed Mar 08, 2006 3:11 pm    Post subject: Reply with quote
Thanks Mike will look at that.
Peter,
Have upgraded TT5 to the latest version - no change.
TT Support very little help in this and will not advsie why x51v will not work. Ho Hum.
Bob
matty2767
PostPosted: Sat Mar 11, 2006 10:49 am    Post subject: Reply with quote
hi all
did you end up getting this to work? i am having the same problems. which settings of hardware and program port have you decided. i have tried a number of combinations but with no luck yet. is there a program that will show gps settings and tell you whether they have connected rather than having to load up tom tom every time and then switch it off again to change a setting.
matt
PostPosted: Sat Mar 11, 2006 11:50 am    Post subject: Reply with quote
Matt, Have a read through this post http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=31569&start=0
It is mostly Bluetooth related and x51v but it might give you some additional ideas
Mike
matty2767
PostPosted: Sat Mar 11, 2006 2:40 pm    Post subject: Reply with quote
thanks for the info. I d/l windfast and it detected my gps on com1 at 4800 no problems. but do I need to set this in the hardware and program ports.?.
although it works in winfast, tomtom cannot see the gps. probably because the ports aren't correct.
matt
matty2767
PostPosted: Sat Mar 11, 2006 4:03 pm    Post subject: Reply with quote
i went to the aximsite.com and follwoed a few of the chaps posts on there. there is a known problem with tomtom and serial ports. if you look in tomtom the text is corrupt. you need to alter one of the keys in the registry to correct it and now it works fine
mburton2
PostPosted: Sat Mar 11, 2006 7:42 pm    Post subject: Reply with quote
Which Registry tweeker did you use?....I found a thread thast quoted a tweeker, but the link was broken.....
I'm trying to get my TTN5.21 working on my NEW Axim X51V, but cannot get the Globalsat-338 working with it....(Like lots of other people)..
I've tried the "other NMEa cable/Baud settings" that DID work on my old iPAQ......
matty2767
PostPosted: Sun Mar 12, 2006 2:57 pm    Post subject: Reply with quote
yeah the link was broken but i managed to find it elsewhere. try this
www.freewareppc.com/utilities/phmregistryeditor.shtml
i moved the file manually on to the pocket pc then ran it from there.
the hack i used was (and i quote from aximsite.com)
Locate HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial
matt
matty2767
PostPosted: Sun Mar 12, 2006 2:58 pm    Post subject: Reply with quote
3. You will see the value name "FriendlyName" has some Russian characters for the value data
4. Change that to Serial Cable on COM1: (include the colon)
5. Make sure you exit registry editor from Tools Exit, that will save the changes properly.
6. Now go to Tom Tom and your wired GPS should be working. You may need to do a soft reset if Tom Tom is still not picking up your wired GPS.
well it worked for me straight away. hope it does for you.
matt
mburton2
PostPosted: Sun Mar 12, 2006 3:32 pm    Post subject: Reply with quote
matt
Hhhm...I tried all that, after manageing to find the registry tweek.....but still no joy for me Sad
I'm using a Globalsat 388 BlueTooth Reciever..
I wouldnt mind, but TWO of my mates bought Avim X51Vs a while back, and the same 338 reciever, and I managed to get BOTH of theirs working, but now I got one, I cant seem to get it to work!! :x
PostPosted: Sun Mar 12, 2006 3:47 pm    Post subject: Reply with quote
mburton2, when you get to the TomTom GPS status page, does the yellow/ blue disk (top RH corner) spin at all, if it isn't doing then you still have a comm port issue, if it is spinning and you are outside, after 20 mins do you see anything? if not it could be the GPS unit is outputing data in SiRF mode rather than the NMEA which TomTom needs, get back with these answers and we get some progress fixing what is wrong - Mike
mburton2
PostPosted: Sun Mar 12, 2006 4:19 pm    Post subject: Reply with quote
Nope, its not spinning.......it IS a comms issue.....
The GPS unit still works on my iPAQ3970.....does that mean its possible for it to be in SiRF mode??......
I was using TTN5.21 on the iPAQ, with the BT338.
I had to install TTN5.0 (I think) from my original TT disk. I then downloaded the Upgrade from the TT site. Then I tried to set up the parntership with eh BT device.....I was wondering, would it be worth re-installing the original TTN5, THEN seeing if I could get the comms sorted with the BT device, THEN upgrading to TTN5.21??
Thoughts?
mburton2
PostPosted: Sun Mar 12, 2006 4:20 pm    Post subject: Reply with quote
Ps. THANKS MIKE!!!!
Page 1 of 3
23.061 (04 Jun 25)
