Pocket GPS World :: View topic - Speed notification
Speed notification
Alexboy45
PostPosted: Fri Feb 24, 2006 6:22 pm    Post subject: Speed notification Reply with quote
Sorry guys another question..
Is there a way for TTN5 to warn you if you are over the speed limit on the road you are on with out the Speed camera POI.. for example if you are on a 30mph road and the TT detects that you are doing 33mpg is there a way for it to tell you with a noise.
Cheers for all the help
peterc10
PostPosted: Sat Feb 25, 2006 1:59 am    Post subject: Reply with quote
Nope, or at least not at present. To do that it would need to know the speed limit on every road in the country and that sort of info is just not recorded or stored on the present maps.
Peter
HTC Sensation
Copilot for USA
gune
PostPosted: Sat Feb 25, 2006 2:14 pm    Post subject: speed notification Reply with quote
hi all:
i think it is not that complicated after all! because destinator 3 had it or has it!
so it is possible. it is a pity tt5 have not done that.
peterc10
PostPosted: Sun Feb 26, 2006 12:27 pm    Post subject: Reply with quote
In order to do it the map being used has to have a record of every speed limit in the country. How else would it know that you are exceeding the speed limit unless it knows what that limit is? AFAIK the maps used by TT do not record that info and never have.
I don't know the Destinator 3 software. What maps does it use?
The nearest TT5 gets to this is that it can switch the screen display off above a certain speed., which you can set. However that speed depends on what you set, not on what the speed limit of the road you are on.
Peter
HTC Sensation
Copilot for USA
alix776
PostPosted: Sun Feb 26, 2006 12:56 pm    Post subject: Reply with quote
try using poiwarner i think that has a over peed warning thought that may only be for speed cameras ie your wanred you are goting to fast for the camera
device Lumia 950 xl
PostPosted: Sun Feb 26, 2006 1:46 pm    Post subject: Reply with quote
Try GPS Speed Sentry - you can set this to warn above selectable speeds, although to use it with TomTom you will need to share the GPS signal (Fransons GPS Gate) for WM2003SE, also configure your hardware buttons so you switch between the applications - Mike
iansmyles
PostPosted: Mon Mar 06, 2006 4:55 pm    Post subject: Reply with quote
I have just purchased a copy of Destinator PN and it does warn you when you are over the speed limit.
Ian M
Mikeact
PostPosted: Thu Mar 09, 2006 1:11 pm    Post subject: Reply with quote
iansmyles wrote:
Ian M
So how does it work then, and what does it show ? Assuming that I'm doing a nice steady 32mph in a 30 area, is it going to continually bug me? ...in which case , I for one would not be interested.
MarkHewitt
PostPosted: Thu Mar 09, 2006 5:15 pm    Post subject: Reply with quote
TomTom maps do record the speed limit, at least near enough they do. Try running one of the demos and you'll see that they keep to the speed limits (plus a little bit)
However the data is nowhere near 100% accurate and considering the legalities of the situation they aren't likely to let people use it. What happens when the speed limit is wrong or has been changed and someone sues TomTom because they weren't warned.
peterc10
PostPosted: Thu Mar 09, 2006 8:59 pm    Post subject: Reply with quote
Mark
I thought the average speed used by TT when calculating a route was determined by the type and class of road, rather than the speed limit. So urban/suburban/rural and minor/A class/B class/unclassified etc. Or have I got that wrong?
In fact in TT3 wasn't it possible to set the speeds you wanted to for these types of road, or have I got that wrong too? I don't know for sure because I haven't used it but I thought I have read complaints from TT3 users that that option was not available in TT5.
Peter
HTC Sensation
Copilot for USA
highwayman212
PostPosted: Sat Mar 18, 2006 10:36 am    Post subject: Reply with quote
Navigon 5 shows the speed limit in the top left hand corner for major routes (motorways / trunk roads not all A roads). Generally these are pretty accurate but obviously when the local authority changes a speed limit these are not updated. The software can be set to warn if your speed passes this (or a user set ammount above).
I find this useful occasionally but would not trust them to be 100% accurate so I only use them with caution.
Legally I would have thought their would be enough get out clauses to avoid Navigon being sued and I am certain it would be no defence in court.
Border_Collie
PostPosted: Sat Mar 18, 2006 1:20 pm    Post subject: Reply with quote
Yes, but I never used it, ETA's were pretty accurate. I believe caravanners found it more useful.
22.064 (26 Jun 24)
