Pocket GPS World :: View topic - How fast should TomTom GPS get a signal?
mrbenn
PostPosted: Mon Mar 06, 2006 6:53 pm    Post subject: How fast should TomTom GPS get a signal? Reply with quote
Hello
I recently bought the Tom Tom gps receiver to go with TT5 for my pda. But it often takes several minutes to pick up a signal. Should I expect this? It's the SiRF2 chip so I was expecting it to fly.
cheers
lbendlin
PostPosted: Mon Mar 06, 2006 8:14 pm    Post subject: Reply with quote
It depends...
- initial fix can take up to 12 minutes (stationary)
- if the backup battery is dead, same applies every time
- if you don't use the receiver for a while, same applies
- if you just used it, switch it off and then on it should get a fix much quicker, sub 60 second.
- if the satellite constellation is not right, it may take longer even under ideal conditions. (five sats in a row are no good for triangulation)
Lutz
TomTom/TeleAtlas NAVTEQ
mrbenn
PostPosted: Mon Mar 06, 2006 10:20 pm    Post subject: Reply with quote
Ok, thanks. I just wanted to check if I'm likely to have a faulty unit or not. I guess not. I don't use it every day, which might have something to do with it. I also find that it's quicker to start from home. Perhaps the trick is to carry the receiver and start it up as I walk to the car.
thanks
Mikeact
PostPosted: Thu Mar 09, 2006 1:18 pm    Post subject: Reply with quote
thanks
In my experince, c**p weather...10/15 minutes, nice day 2/3 minutes.
MarkHewitt
PostPosted: Thu Mar 09, 2006 5:13 pm    Post subject: Reply with quote
SRiF2 is your problem. This is very old now and you should really be using SRiF3. However your time to first fix is typical.
22.101 (03 Oct 24)
