Pocket GPS World :: View topic - TomTom and Outlook
TomTom and Outlook
montyburns
PostPosted: Thu Mar 09, 2006 9:21 am    Post subject: TomTom and Outlook Reply with quote
My other half says she read somewhere that you can link the TT5 with the address book in Outlook?
Can't find a way to do this.
Did she imagine it?!
Etwell
PostPosted: Thu Mar 09, 2006 11:06 am    Post subject: Reply with quote
You can import Contacts into a PDA running Windows Pocket PC....
Then from within Contacts you can/should be able to navigate to an address.
However.... it can be a bit iffy. See this link that was about it.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=34710&highlight=etwell
peterc10
PostPosted: Thu Mar 09, 2006 11:19 am    Post subject: Reply with quote
As I said in the post that Etwell linked to if you are already synced to your PDA (running PPC) then the facility should be ther. Go into contacts on the PDA, press and hold one and a list of options came up. If you have "navigate to" and "find on map" click on them and TT should launch and do what you asked It can only do Nvigate to if you have a GPS fix but will do find on map without fix.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
schneid
PostPosted: Thu Mar 09, 2006 7:12 pm    Post subject: Reply with quote
TT 5 PPC installs a Pocket Outlook plugin when installed. You simply tap and hold a contact and "Navigate To" will pop up. Click OK and TT will open with your Contact as the destination.
The Contacts have to be enter just so, i.e. in the standard TT needs.
Other Today plugins can break it.
To import your address book from your PC, I'd import it Streets$Trips/Autoroute and have POIconverter make it a TT custom POI file.
montyburns
PostPosted: Thu Mar 09, 2006 8:00 pm    Post subject: Reply with quote
Woo! Cool! 8) Thanks!
This actually works! I'd been trying to do it from within TT5
Now all I need to do is actually put some addresses into Outlook (a couple of hundred phone numbers, but only two addresses! Sad )
peterc10
PostPosted: Thu Mar 09, 2006 9:08 pm    Post subject: Reply with quote
If you are going to put the adresses in take a bit more time. Instead of just entering address in address box in Outlook click on the address button next to it. That will bring up another box that will prompt you to break down the address into components (street city etc). that way TT is much more likely to recognise the address.
Peter
HTC Sensation
Copilot for USA
Border_Collie
PostPosted: Fri Mar 10, 2006 1:53 am    Post subject: Reply with quote
But be aware that if the house has a name instead of a number or you are visiting a block of flats, it doesn't work. It's best in these cases to use the postcode.
Border_Collie
PostPosted: Fri Mar 10, 2006 1:54 am    Post subject: Reply with quote
Use the postcode search from within TomTom, is what I should have said.
23.054 (28 May 25)
