Umster Banned
Posted: Sun Mar 05, 2006 6:31 pm Post subject: Tomtom 5 on Ipaq 3970 with Windows Mobile 2002 not working?? |
Please can I ask for some help.
I have an old Ipaq 3970 and I want to use TomTom 5 on it. 8)
List of equipment used.
Ipaq 3970 with Windows mobile 2002
TomTom 5 Bluetooth Receiver MkII
Software: TomTom 5 Nav.
I have installed TomTom 5 on my SD card, plugged it into the Ipaq and it seems to work ok, however I can't seem to make a connection with my Bluetooth receiver. I has paired it up ok and made a bond.
When running TomTom nav, it does not seem to recognise the Bluetooth receiver, :x
Where am I going wrong? Do I need Windows mobile 2003?
Thanks |
peterc10 Frequent Visitor
Posted: Sun Mar 05, 2006 6:52 pm Post subject: |
You need to tell TT what receiver you are using. Go into change preferences then Show GPS status. Then hit configure. At first choose Tom Tom BT receiver and see if it pairs. If not don't choose other BT connections. Instead go for Other NMEA. Choose a port number and then in the next window a Baud rate. You may need to experiment a bit with those to get them right. Then you should be OK - but you will need to leave it for 20 to 30 minutes outside with a clear view of the sky to get your first lock. _________________ Peter
HTC Sensation
Copilot for USA
Umster Banned
Posted: Wed Mar 08, 2006 12:23 am Post subject: |
Thank you for taking the time to reply to me,
I went into TT preferences, hit config and selected tomtom bluetooth receiver and it did not pair up. If I choose another BT connections, what should the port number be?
I have left the BT receiver out for an 1hr.
Thanks |
Posted: Wed Mar 08, 2006 1:04 am Post subject: |
Its not a case of pairing up - that is done before. Its telling TT where to look for whats paired I think. You need to wait 20 or so minutes with a clear sky view to see if it works. That should work if you have a TT BT receiver. If not try other NMEA (not other Bluetooth) and experiment with the post number and baud rate _________________ Peter
HTC Sensation
Copilot for USA
Umster Banned
Posted: Wed Mar 08, 2006 1:26 am Post subject: |
peterc10 wrote: | Its not a case of pairing up - that is done before. Its telling TT where to look for whats paired I think. You need to wait 20 or so minutes with a clear sky view to see if it works. That should work if you have a TT BT receiver. If not try other NMEA (not other Bluetooth) and experiment with the post number and baud rate |
Peter,
How can I test the paring up has worked?
Thanks |
mburton2 Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_005.gif)
Posted: Wed Mar 08, 2006 2:55 pm Post subject: |
I have an 3970, with a BT receiver (GlobalSat 338), running PocketPC 2002....so it WILL work!
The settings I have are:
Other NMEA GPS
Baud rate = 38400
BlueTooth Serial comm port 8
Hope that helps... |
Posted: Wed Mar 08, 2006 3:00 pm Post subject: |
IF the Receiver is "Talking" to the iPAQ, the little black/yellow segmented circle at the top-right of the screen will look like its turning (This may take 10-20 seconds after you hit the "Bluetooth Serial coms port 8" option (Well, it did on mine!) |
Umster Banned
Posted: Wed Mar 08, 2006 11:17 pm Post subject: |
mburton2 wrote: | IF the Receiver is "Talking" to the iPAQ, the little black/yellow segmented circle at the top-right of the screen will look like its turning (This may take 10-20 seconds after you hit the "Bluetooth Serial coms port 8" option (Well, it did on mine!) |
Thank you for this info, I will test it out. ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
