madskipper Occasional Visitor
Posted: Sun Mar 05, 2006 12:59 pm Post subject: Streetpilot I3 crashes after load of speed cam POI |
I added the speed cam POI and a couple others but now when I go to custom points my unit shuts off. It also can't connect to satilites now. I tried the reset which seemed to have worked but my unit still crashes. Is there a fix for this. |
Almahadeus Frequent Visitor
Posted: Sun Mar 05, 2006 1:10 pm Post subject: Re: Streetpilot I3 crashes after load of speed cam POI |
madskipper wrote: | I added the speed cam POI and a couple others but now when I go to custom points my unit shuts off. It also can't connect to satilites now. I tried the reset which seemed to have worked but my unit still crashes. Is there a fix for this. |
Welcome madskipper. It could be that your unit is protesting against you paying fo the latest database!!! |
Posted: Sun Mar 05, 2006 5:22 pm Post subject: |
Almahadeus are you joking? It is suposed to take POIs with the loader. There must be some way to get it to least work. As I said it won't even pick up a satilite. I have only had the unit for a couple of days. |
Posted: Sun Mar 05, 2006 5:35 pm Post subject: |
Have you been through the Garmin for Dummies and the FAQs and info threads? It is all there. |
Beerbellybill999 Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Mon Mar 06, 2006 10:41 am Post subject: |
I had something similar on my unit. You may have a currupt POI file. Try and reload a file that you know works as this will overwrite the file.Hopefully this will solve it
In my case I couldn't even do this and my unit kept reseting everytime I tried to load new POI. It was sent back to Garmin who diagnosed a faulty transflash card and replaced it and everthing is now fine. _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
Posted: Mon Mar 06, 2006 10:19 pm Post subject: |
Thanks the problem must have been a currupt file. I couldn't rewrite on it either because my unit kept reseting. I only had the unit for a couple of days, so I should be able to possibly swap it.
The trouble is I think I will be affraid to load any POI flies to it after this experience. |
