Pocket GPS World :: View topic - Camera POIs - what am I doing wrong?
NigelO
PostPosted: Sun Mar 05, 2006 11:25 pm    Post subject: Camera POIs - what am I doing wrong? Reply with quote
I'm using an O2 Exec and CP6, v 068
I've downloaded the camera database (in several formats - single file, speed zoned, camera types) and in each case, I've opened up the OV2 files (in wordpad) and replaced all "@" with " AT ". I also changed the names of the files to "Speed Camera", which CP6's TTS manages to use perfectly.
However, I'm still getting the warning showing with the "@" symbol, as well as the infuriating splitting of the camera warning message.
Also still getting 30 seconds of the warning period duration - anyone twigged how to shorted it?
PONDEROUS
PostPosted: Mon Mar 06, 2006 1:02 pm    Post subject: Reply with quote
Sounds as if you might be using both OV2 and Data Download Wizard versions of the cameras at once. If you edited the @ on the OV2 version but not the DDW and still had Safety Cameras checked under Travel & Transportation POI Alerts, that would cause your problem.
Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005
22.063 (19 Jun 24)
