Pocket GPS World :: View topic - just updated firmware of TT1 to version 5.420 problem
trying2
PostPosted: Fri Mar 03, 2006 11:31 pm    Post subject: just updated firmware of TT1 to version 5.420 problem Reply with quote
hi,
just updated TT1 to firmware version 5.420 and switched it on and it says no GPS, but all else seems ok, what can i do....tried reset...nothing.
PostPosted: Sat Mar 04, 2006 9:18 am    Post subject: Reply with quote
You will have to leave it for upto 12 minutes to collect all the data needed, on the first restart.
trying2
PostPosted: Sat Mar 04, 2006 1:35 pm    Post subject: Reply with quote
almost cried last nite, felt so helpless!!
events;
1.received new tt1
2. read forums
3. replicated/copied original sd to a 512mb using cardreader
4.put away original sd, and tested bkup sd -brilliant
5.bkup sd worked fine but was version 5.410
6. went to tt site and downloaded 5.420.exe and placed in bkup sd
7.followed installation it said installation complete with 5.420
8.switched on tt1 and it says no gps......everything else menus etc the same
9.erased bkup sd and copied original firmware 5.410 back onto bkup sd ...same message........but before i updated, that version work!!!!!!
.........above procedure used cardreader not data transfer cable............
........then retried above with data transfer cable...same message.....
NB it worked beautifully, until the update...which somehow affected the gps??????????
10. last resort tried original sd v5.410....same message
11. removed all sd cards from tt1 and reset but still no gps
[/list]
philip4242
PostPosted: Sat Mar 04, 2006 2:40 pm    Post subject: Reply with quote
I've been in a similar situation to you, although it was a firmware update to my Micromaxx MDPPC150 (Mio 168 clone) that had me in a little panic !
The confusion may be that some TomTom software, when it says 'No GPS', really means 'No GPS FIX'.
The Upgrade Instructions should have said that you'll need to wait a time (Oldboy was suggesting 5 minutes, whereas I had to wait about 20) with the GPS having a good, unobstructed, clear view of the sky for all the satellites visible to it to be 're-acquired'.
While this is happening, (although I don't know if this is applicable to your particular GPS) tapping on the 'GPS signal strength' bars on the main map screen, then on the Battery Charge State/Satellites area, takes me to a page where the signal strength for each visible satellite is shown.
There's also a small sectored circle which rotates to show that data is being received from the satellite receiver.
If that's turning - all's well - just give it time !
If not (and another try at resetting to 'Factory Defaults' doesn't do any good), I think you'll have to contact TomTom.
Getting older and more senile by the minute !
Philip
trying2
PostPosted: Sat Mar 04, 2006 3:08 pm    Post subject: Reply with quote
Tears of joys in my eyes!!!!!
yes that circular thing is there.......i sent the other half to walk around with my tt1 out in the cold..............came back WITH A SIGNAL!!!!!!!!!
so relief was i.............yoda
thank you for your excellant and well timely and detailed advise...........i was literally pulling all my hair out...and my other half near breaking point with me....
what you told me.......they should incl in the manual........jesus
now i have version 5.420 and most importantly gps..........bless u!!!!!!!!!!
