Pocket GPS World :: View topic - Problems loading camera database
Trojan680
PostPosted: Fri Mar 03, 2006 10:49 am    Post subject: Problems loading camera database Reply with quote
I have an iPAQ 2210 runninh TT Nav 3. I have not been able to make the POI edit work. Have downloaded it bot when I try to sync it wants me to manually load proxy settings??
Gave up on that and downloaded the tt ov2 speed camera package that shows different camera's, speeds etc. Sync'd this with PDA in cradle, copied over to PDA, saved in Navigator folder but it won't run on Navigator??
Any ideas?
Dom. Crying or Very sad
PostPosted: Fri Mar 03, 2006 11:37 am    Post subject: Reply with quote
I assume you have coppied all the files (.bmp and .ov2) across to the Great_Britain Navigator Map folder and they are in there as seperate files not in a folder? - if so do you use CheckPOI for the warnings, if this is the case you will need to go to CheckPOI and select overlay settings and reconfigure the warnings using the properties control (lower LH of the screen) - I only know this in some detail as I had to configure someone else's machine running TT3/ CheckPOI the other day, I even put some Liz voice warnings on it for him at the same time - Mike
22.101 (03 Oct 24)
