Pocket GPS World :: View topic - HELP! Beginner unable to get camera database onto Garmin i3
Cameron
PostPosted: Fri Mar 03, 2006 12:55 am    Post subject: HELP! Beginner unable to get camera database onto Garmin i3 Reply with quote
I have just bought a Garmin i3 and subscribed to the forum. I have downloaded both database options offered for the Garmin 3i BUT the POI LOader can't find any csv files in the folder (and neither can I!). Are the csv files elsewhere (?), do I have to rename the downloaded files (?). I'm probably doing something fundamental wrong but then I am just a beginner.... any suggestions?
Pocketgps
PostPosted: Fri Mar 03, 2006 1:11 am    Post subject: Reply with quote
Have you un-zipped the file(s) you downloaded.
If you don't have a zip utility but are using Windows XP then right click on the file(s) you downloaded and then click on Explore. Windows will then display the files for you. just drag and drop them into the Garmin folder and then point PoiLoader at that folder.
Cameron
PostPosted: Fri Mar 03, 2006 1:25 am    Post subject: Reply with quote
:D Hi & thanks.... that did the trick.... and I have also managed to load some other POI files from other sites aswell so I should now always be able to find a pub, parking space , hospital(!) or MacDonalds.... ut not necessarily in that order.... thanks.
Pocketgps
PostPosted: Fri Mar 03, 2006 3:09 am    Post subject: Reply with quote
Just a note for you if you are not aware, you need to place ALL of the poi files in the same folder when you load them to the i3, as PoiLoader deletes ALL previous poi(s) each time you use it.
Also see HERE
Nickwolf
PostPosted: Fri Mar 03, 2006 9:08 am    Post subject: Reply with quote
Cameron,
Have you seen MaFt's excellent site:
http://www.MaFt.co.uk/garmin/download.htm
Nick.
Cameron
PostPosted: Sat Mar 04, 2006 11:58 am    Post subject: Reply with quote
:D Thanks Nickwolf and Fanatic........ I've managed to download the MaFt POIs and the speed camera database and have placed everything into the same folder as advised...... Cheers
22.064 (26 Jun 24)
