mattyduk Occasional Visitor
Posted: Thu Feb 02, 2006 4:01 pm Post subject: O2 Exec - which TomTom Version ? |
One of our directors has just got a O2 exec (WM5).
Which version of Tom Tom (if any) can we buy to run on it ?
cheers
Mat |
Posted: Thu Feb 02, 2006 4:54 pm Post subject: |
you need TTN 5,21 I am not too sure if a new copy of TomTom will ship with this loaded but you can download it from the TomTom web site for free and install it. Mike |
Posted: Thu Feb 02, 2006 5:01 pm Post subject: |
thanks for the reply.
Is it the smartphone version I require or Pocketpc (as the xda exec is a bit of both !) |
Posted: Thu Feb 02, 2006 6:43 pm Post subject: |
Its the Pocket PC version you need for the Exec, you also need a Bluetooth GPS to work with Exec, you cannot use a cabled (wired) one with this device. Mike |
alix776 Pocket GPS Moderator
Posted: Mon Feb 06, 2006 5:53 pm Post subject: |
youll need a bluetooth gps receiver to as that is only the mapping asnd application you getting there _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Feb 06, 2006 5:57 pm Post subject: |
alix776 wrote: | youll need a bluetooth gps receiver to as that is only the mapping asnd application you getting there |
yeah, I've got one of those.
cheers |
Posted: Mon Feb 06, 2006 7:06 pm Post subject: |
This will do fine in addition to your BT GPS unit you will need an SD card of the required capacity to install the map data to- the Exec works fine with upto 2GB of card (thats the largest I have tried to date) - Mike |
Posted: Wed Mar 01, 2006 7:16 pm Post subject: |
when running the software installer, it doesn't see the exec.
Any suggestions ? |
Posted: Wed Mar 01, 2006 8:07 pm Post subject: |
Have you put active sync on to the PC - the Exec will have come supplied with the application - without this your PC will not see the PDA/ Phone - Mike |
Posted: Thu Mar 02, 2006 10:53 am Post subject: |
activesync is installed, as we've used it to install other products.
The TomTom installer just doesn't see the exec
I noticed on the packaging for tomtom that it doesn't mention the exec being compatible, but I suppose its difficult for them to note every model.
We definately bought the pocket pc version as suggested on this thread. |
Posted: Thu Mar 02, 2006 10:57 am Post subject: |
Please re-read my OP in this thread - pay attention to the TTN5,21 - without this it will not load, you can download this from www.tomtom.com - the chances are the software on the CD's will not be fully upto date - Mike |
Posted: Thu Mar 02, 2006 11:09 am Post subject: |
thanks for the reply. I've now watched the MD try and install it, and this timed it picked up the exec (typical, IT person watches user install software and it works fine !)
Thanks again for your help |
seraphaxg Occasional Visitor
Posted: Sun May 07, 2006 10:13 am Post subject: |
mattyduk wrote: | thanks for the reply.
Just to advise, you are quite correct in saying it's a bit of both- the WM2005 operating system is capable of handling existing smartphone 2003 and PPC versions (I've tried both versions of Tom Tom on my MDA Vario and they both work). The main difference is that you don't get touch screen enabled software on the Smartphone versions- so, always aim for PPC versions of software on the XDA. |
