Pocket GPS World :: View topic - poi's garmin i3
poi's garmin i3
bazelk
PostPosted: Tue Feb 28, 2006 9:37 pm    Post subject: poi's garmin i3 Reply with quote
Am i doing somthing wrong?Bought my i3 yestarday loaded the speed camera file(jan06) then the other poi's ie petrol stations, Mcdonalds etc etc but the speed camera function dosn't work, approched three cameras above the speed limit(slowed before going through) but no warning.
Do I have to load both at the same time from one file?
what files do I have to use from the unziped camera file?
Regards
Almahadeus
PostPosted: Tue Feb 28, 2006 9:42 pm    Post subject: Re: poi's garmin i3 Reply with quote
Regards
Yes for the first question
use the .csv files with their similarly named .bmp (for icons)
bumpkin
PostPosted: Tue Feb 28, 2006 9:56 pm    Post subject: Reply with quote
Also upload all your POIs in one go. Put them all in the same folder and upload from there. The 3i deletes all custom POIs on the machine before each upload so if you're only uploading one set at a time you'll only be getting that last one once you've finished.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
bazelk
PostPosted: Tue Feb 28, 2006 10:02 pm    Post subject: Reply with quote
Sorry to sound thick but this is all new to me, You say csv files and bmp,
but there is a file in there called garmin, and a csv file, do I use both? and what about the file alternative bmp is that the one you mean. also is the file named speed zoned anything to do with it?
Regards
paulhgc
PostPosted: Tue Feb 28, 2006 10:28 pm    Post subject: Re: poi's garmin i3 Reply with quote
Regards
where dod u get the mcdonalds pois from ?
bazelk
PostPosted: Tue Feb 28, 2006 10:46 pm    Post subject: Reply with quote
Try this, I think it was here! if not get back to me and I will dig into my history of hits.
www.MaFt.co.uk/garmin
Regards
bazelk
PostPosted: Tue Feb 28, 2006 11:12 pm    Post subject: Reply with quote
Hi folks, done what you said all is now aok will try the camera part out on the way to work. I only used the file that said garmin in the zipped folder,
Many thanks
I will be subscribing to this site, its worth every penny(via paypal as and when available)
PostPosted: Wed Mar 01, 2006 11:11 am    Post subject: Reply with quote
in which case you'll get a specific garmin download which will make it MUCH easier to get the camera's on there.
Almahadeus
PostPosted: Wed Mar 01, 2006 5:12 pm    Post subject: Reply with quote
You could almost sense the enthusiasm there.
PostPosted: Wed Mar 01, 2006 5:58 pm    Post subject: Reply with quote
8O :P
22.094 (25 Sep 24)
