MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Thu Jan 26, 2006 3:12 pm Post subject: Can't See Speed Camera Icons In Navigation Mode (FAQ) |
Q: Why can't I see the speed camera icons when I am in 'navigation' mode? They show up in 'map' mode...
A: The i3 is set up in such a way that POI icons will only show up when you are above the speed limit. Therefore, you will not see a speed camera icon unless you are speeding. At present there is no way to change this and Garmin have stated that they believe that if all POI icons were shown all the time it would clog up the screen too much. |
Ash10 Pocket GPS Verifier
Posted: Thu Jan 26, 2006 3:59 pm Post subject: |
It is possible to make the i3 *always* display speed camera locations, and to *always* warn of them - provided that:
- speed information is stripped from the database CSV files.
- camera POI have been installed using the Manual option in PoiLoader.
- trigger by distance (not by speed) was specified in PoiLoader.
To strip the speed information from the CSV files, proceed as follows:
- if you have Excel, use the Search/Replace function to search for "@?0" (without quotes) and replace with nothing, ie: leave the box empty.
- if you don't have Excel, you can use Notepad (which is part of Windows) instead. However, the Search/replace function in Notepad doesn't support wildcards - so you'll have to search separately for "@70", "@60", "@50" and so on.
(If there's sufficient demand, I'll knock up a quick batch file to automate this process.)
For trigger distances I use the following values:
- Gatso/Truvelo and Temporary cameras - 1320ft (1/4 mile)
- Redlight cameras - 660ft (1/8 mile)
- Mobile cameras - 2640ft (1/2 mile)
Note that although camera locations will always be displayed, you will only receive the initial "bing bong" warning as you approach a camera - you won't get the repeating "bing bing bing" warning if you're over the speed limit (as the i3 won't know what the limit is). |
NoLCD Occasional Visitor
Posted: Thu Jan 26, 2006 10:22 pm Post subject: |
I did this and created a new bmp to go with the new file but kept the original speed triggered version.
So I get a proximity alarm and the usual alarm if speed too high (tut tut). i.e. the speed feature works as normal, but I also always have the new bmp appearing in the cameras location irrespective of speed. It gets a bit busy but I have got used to it. |
Posted: Thu Jan 26, 2006 10:23 pm Post subject: |
NoLCD wrote: | I did this and created a new bmp to go with the new file but kept the original speed triggered version.
good idea, might try that myself! |
Aitch2 Regular Visitor
Joined: Jan 22, 2006 Posts: 226 Location: South Coast, UK
Posted: Fri Jan 27, 2006 12:52 am Post subject: |
Ash10 wrote: | (If there's sufficient demand, I'll knock up a quick batch file to automate this process.) |
You couldn't knock up a Hobbit POI file by any chance? :privatejokeicon:
Aitch |
brynster Occasional Visitor
Posted: Tue Feb 28, 2006 12:59 pm Post subject: help |
can you tell me do i get rid of @70 or @70" or "GATSO:33@70" im not to bright so could do with some help with just which part to get rid of |
Posted: Tue Feb 28, 2006 1:08 pm Post subject: Re: help |
brynster wrote: | can you tell me do i get rid of @70 or @70" or "GATSO:33@70" im not to bright so could do with some help with just which part to get rid of |
In theory you could get rid of the whole "GATSO:33@70" - but it's useful to keep the type of camera (to help you spot it at the roadside), and its reference number (for report inaccuracies in the database etc.)
Just get rid of the @70, so that you're left with "GATSO:33" in the example above. |
Posted: Tue Feb 28, 2006 1:37 pm Post subject: thanks |
thanks 4 that Ash10 ill give it a go trying to find a d/l for excel as doing it with note pad looks like a long job. thanks for your help! |
Posted: Tue Feb 28, 2006 1:55 pm Post subject: Re: thanks |
brynster wrote: | thanks 4 that Ash10 ill give it a go trying to find a d/l for excel as doing it with note pad looks like a long job. thanks for your help! |
even in notepad it's an easy job.
open the file then press 'ctrl + h' for replace. 'find what': @20 and leave 'replace with' blank. press replace all. then change it to @30, @40 etc then remove all the remaining @
peasy
MaFt |
Posted: Tue Feb 28, 2006 1:59 pm Post subject: Re: thanks |
MaFt wrote: | even in notepad it's an easy job.
peasy |
Even peasier (!?) would be to search for @ and replace with _ (underscore), and you'd only need to do that once for each CSV file... 8) |
Posted: Tue Feb 28, 2006 2:43 pm Post subject: thanks guys |
thanks for your help guys my fingers were starting to hurt. ill upload cameras again with changes ive made. once again thanks for your help :D m |
Posted: Tue Feb 28, 2006 3:06 pm Post subject: Re: thanks |
Ash10 wrote: | MaFt wrote: | even in notepad it's an easy job.
peasy |
good call, then if ya change your mind you still have the relevent speed data :D
MaFt |
Posted: Tue Feb 28, 2006 6:13 pm Post subject: |
:D :D :D sorted works a reat hnk 4lelp |
Posted: Tue Feb 28, 2006 6:16 pm Post subject: |
:D :D :D previous mesage was a mess it should have read thanks 4 all your help i3 is working a treat showing all bmp of cameras. cool 8) 8) 8) |
bevisnorth Occasional Visitor
Posted: Sat Mar 25, 2006 5:31 pm Post subject: |
Is it possible to have the speed displayed at all times? |
