Pocket GPS World :: View topic - POI Capture software
ned1
PostPosted: Mon Feb 27, 2006 7:15 pm    Post subject: POI Capture software Reply with quote
I have found two safety cameras and would like to send them in,
What I would like to know is can I use the new p.o.I. software with my ttg 300 which is running 5.200 and if not can I up-date to 5.202 (if so where from !) also will I be able keep my setting.
Ned
PostPosted: Mon Feb 27, 2006 8:55 pm    Post subject: Reply with quote
You can download 5.202 from http://myweb.tiscali.co.uk/oldboy/TomTomUpdates/ttgoapp-5.202.zip
Just Copy the 6 unzipped files to the Root of the SD Card.
Which settings do you mean?
It will give you a new data.chk file but the cfg File in the Map Folder stays.
ned1
PostPosted: Mon Feb 27, 2006 10:25 pm    Post subject: Reply with quote
Thanks for that oldboy,
The setting I was taking about are my addresses, speed limits, cameras, etc
Ned
ned1
PostPosted: Mon Feb 27, 2006 10:43 pm    Post subject: Reply with quote
Oldboy,
Sorry about this but you say Embarassed
" Just Copy the 6 unzipped files to the Root of the SD Card."
What do you mean, unzip, copy and paste into the folder or open the folder and replace them, then add the "install bif, file 1kB" as this is not in my folder !
Thanks for your help
ned
PostPosted: Tue Feb 28, 2006 8:05 am    Post subject: Reply with quote
You should already have a Full Backup of your Card, so all you need to do is Unzip the download on your PC and Copy/Paste the 6 Files to the Root of the SD Card.
When asked if you want to Overwrite, Click 'Yes to All'.
The Install.bif should be in the Root of the SD Card, not in a Folder. All the Files go in the same place and replace Files with the same name.
The only File you might have to alter is data.chk. If you have a modified your existing data.chk then you will have to modify the new one as it will have a different build number.
22.062 (12 Jun 24)
