Pocket GPS World :: View topic - tom tom 300 problem
tom tom 300 problem
Goto page Previous  1, 2
sgould
PostPosted: Sun Feb 26, 2006 9:39 pm    Post subject: Reply with quote
Try deleting voices - these are stored in the NUMBERED "data**.chk" files. You must leave one "data05.chk and data05.chk are the UK English ones. You can also remove the .vif files which go with them as a pair. Again engf.vif and engm.vif are the UK English.
LEAVE "data.chk" itself alone. It carries the warning sounds and is needed.
If all else fails buy a 256 SD card and use that. It will have plenty of room on it for one map and a few extras.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
pianoman
PostPosted: Mon Feb 27, 2006 2:12 pm    Post subject: Reply with quote
thank you guysi am off and running again and made good backup,just cant get spolash screen back on i have followed instructions to the t ,but to no avail any ideas?
once again help much appreciated
ricky
Tumbleweed
PostPosted: Mon Feb 27, 2006 8:31 pm    Post subject: Reply with quote
pianoman wrote:
thanks for the great info i have almost got it but as i go to reload the uk map it nearly loads ,but right at the end it says the destination is full can i delete something it used to have the gb maps nand poi [speed cams ] so i know there should be enough space on sd [i believe its 128 mb]
i think we are almost there though ;
best wishes to all who have tried to help me
dont screw about deleting files you've made it difficult enough as it is, just get a bigger SD card, you can geta 256Mb one for around a tenner.
tw
pianoman
PostPosted: Mon Feb 27, 2006 10:13 pm    Post subject: Reply with quote
tw thanks for good advice i somehow have[with all the help i have been given in this forum ] managed to get it up and running again ,i have backed up the files now for future probs
cheers ricky
Tumbleweed
PostPosted: Tue Feb 28, 2006 5:26 pm    Post subject: Reply with quote
cheers ricky
Once you have got a bigger card you can look for a file called splash.bmp and copy it to the card, it should be in the root directory.
Also there are some forums on here with many different splash files if you fancy something different from the TT original one, or you can make your own its not difficult.
Tw
pianoman
PostPosted: Wed Mar 01, 2006 11:07 am    Post subject: Reply with quote
thank for the infos
best ricky
sunter18
PostPosted: Tue Mar 07, 2006 8:35 pm    Post subject: Reply with quote
i have also encountered a similar problem, any body can help please see page 60 of this forum titled 'help please. My TT GO 300 will not read card info'
Browny_37
PostPosted: Mon Mar 20, 2006 11:03 pm    Post subject: Reply with quote
I had a similar problem after trying to update my tom tom.
TomTom support told me to do this:
Please do the following:
-Connect the GO300 to your PC
- Go to 'My computer' and brows the SD card
- Look for the files 'ttsystem' (boot loader) and 'system' (application) in the root directory of the SD and delete them
- If the root directory also contains files called 'ttsystem.temp' and 'system.temp' remove them too
- Then run the update 5.420 again, but select 'add/remove extra features' first in order to remove one of the two preinstalled voice prompts. This will free up some more space on the SD
- After removing one voice select 'install application' to install the update 5.420 onto the memory card again.
Hope this helps as it did me.
Page 2 of 2
22.063 (19 Jun 24)
