paulhgc Regular Visitor
Posted: Sun Feb 26, 2006 2:57 am Post subject: i3 ariel |
best place to get a ariel for your i3 street pilot ? |
Ayla Occasional Visitor
Posted: Sun Feb 26, 2006 3:04 am Post subject: |
Hi Paul, I see you've taken the plunge and bought yourself an i3. Why do you think you need an arial? I have a heated windscreen and I am having absolutely zero problems picking up a signal, even in a built-up area (ie. my driveway between two houses, with the garage right in front, therefore a VERY narrow strip of sky above).
It does take quite a while the first time you use it, and I found I had to go to an open area - the nearest supermarket parking lot worked well. After that, it's just a few seconds.
I have mine mounted in the right hand corner where there are no wires in the windscreen. It's small enough that you can do that. It also means that when you glance at it, you are also glancing at on-coming traffic peripherally, which is an added safety measure. |
Posted: Sun Feb 26, 2006 3:26 am Post subject: |
ayla i only purchased today but on the way home it kept saying calculating ...but i have upgraded the firware so im hoping this will fix it ...... but if not i may need a ariel ... hence the post |
Posted: Sun Feb 26, 2006 10:59 am Post subject: |
If you do need one Maplin do them for £9.99. |
Alang Occasional Visitor
Posted: Sun Feb 26, 2006 11:31 am Post subject: |
Leave it "turned on" in the garden for 20 mins. It will then lock onto the Sats.
Look in FAQ's
Hope it helps
Alang |
Aitch2 Regular Visitor
![](modules/Forums/images/avatars/111346189843d4c3b5d9267.jpg)
Joined: Jan 22, 2006 Posts: 226 Location: South Coast, UK
Posted: Mon Feb 27, 2006 9:02 pm Post subject: |
will be testing the i3 in central london tommorow without a ariel and see if it works
has anyone used this little mean machine in central london yet ? |
