_Brian_ Occasional Visitor
Joined: Feb 19, 2006 Posts: 30 Location: Hampshire, UK
Posted: Fri Feb 24, 2006 9:48 pm Post subject: A201 self restores TomTom N5 software after dead battery? |
I had an unexpected outcome to a dead battery on my A201(WM5). I recharged the battery enough to turn on the unit. When I did, the A201 showed the Mio splash screen and then proceed to load software (from where, I don't know). During the loading process, it displayed a horizontal loadling status bar that, when completed switched to the standard WM5 display. The added programs, including TOMTOM Nav 5 where there and when executed worked perfectly.
My question is does WM5 have an auto back-up feature that backs up not only base software, but added software as well. If the is the case, the need for a 3rd party back-up program has just deminished.
Thanks in advance
Brian |
Posted: Fri Feb 24, 2006 11:24 pm Post subject: |
This is exactly what WM2005 should do as all data is stored in ROM style memory, i.e. non-volatile so a power outage shouldn't affect the data loaded - I still use a back-up but its not been needed as yet - Mike |
Posted: Sat Feb 25, 2006 10:02 pm Post subject: |
Mike,
Thanks for the response. Nice to know the back up feature is there (& works) in WM5. Do you know if the data (& applications) stored in ROM would remain after a hard reset. If it does, I assume that the need for a back up program would be to restore if a program and configurations were corrupted on the PDA. Is this correct/
Brian |
Posted: Sat Feb 25, 2006 10:07 pm Post subject: |
If you do perform a "Hard Reset" then that is exactly what will happen - back to the same state the device was in when it came out of the box, so back-up software is still of use with the 2005 devices the hard storage just prevents the power outage loss of programs, which are more frequent than the need for a full hard reset - Mike |
