Pocket GPS World :: View topic - tt300 in us
tt300 in us
r00k1e
PostPosted: Fri Feb 24, 2006 10:59 pm    Post subject: tt300 in us Reply with quote
hi i am off to florida shortly and wondered if any one had had any problems charging their tt300 etc over there either from the car or using the mains any help \ advice would be grateful
PostPosted: Sat Feb 25, 2006 3:38 am    Post subject: Reply with quote
Your car charger will work there fine. I have seen reports that some Florida car companies disable the cigar lighter power socket though, so best to check with them.
Charging from mains depends on what sort of charger you have. If it is a normal transformer device with a label saying something like "220-240 Volts AC input" it wont work.
If it is a switch-mode type that clearly says something like "100-240 Volts AC input" you should be OK, but obviously will still need an adaptor plug to connect it to their mains supply.
r00k1e
PostPosted: Sun Feb 26, 2006 12:18 am    Post subject: Reply with quote
thanks for that andy will check on the lighter when i book the car
22.064 (26 Jun 24)
