Juey Occasional Visitor
Posted: Thu Feb 23, 2006 7:12 pm Post subject: |
no extra bmps
version 5.201 - if thats what you mean by 'firmware' _________________ RX-8 going BEEP since 19/3/2004
TomtomGo going Mooooooo since 8/9/2004 |
Posted: Thu Feb 23, 2006 7:15 pm Post subject: |
I'm using one of those images now - the mazda badge
saved it as a bmp file called 'splash'
dragged it into tomtomgo (e)
no joy
blank screen on powr up/down _________________ RX-8 going BEEP since 19/3/2004
gazza1 Regular Visitor
Joined: Jan 01, 2006 Posts: 90 Location: West Sussex, UK
Posted: Thu Feb 23, 2006 7:37 pm Post subject: |
rotated it? |
Posted: Thu Feb 23, 2006 7:42 pm Post subject: |
yup.
Father ted: "Now Dougall I want you to concentrate very hard, these cows (pointing to toy plastic cows on the table) are very small, those cows (points out of the window) are far away"
Its a tomtomgo classic if that makes any difference _________________ RX-8 going BEEP since 19/3/2004
Posted: Thu Feb 23, 2006 7:45 pm Post subject: |
Never had any problems on my classic. I'm stumped. Can't see the problem, maybe somebody else has any ideas? |
Andy_P Pocket GPS Moderator
Posted: Thu Feb 23, 2006 7:48 pm Post subject: |
Jeeeezus!
It needs to be called splash.bmp!!!!! |
Posted: Thu Feb 23, 2006 7:51 pm Post subject: |
tried that, doesn't work either _________________ RX-8 going BEEP since 19/3/2004
Posted: Thu Feb 23, 2006 7:52 pm Post subject: |
I was assuming that he had already read that on your previous post. |
Posted: Thu Feb 23, 2006 8:51 pm Post subject: |
Sorry, stressful day.... |
Posted: Fri Feb 24, 2006 12:38 pm Post subject: |
is it because I 'replaced' the original tomtom splash
ie is their some sort of coding that has been deleted that was in the original splash file? _________________ RX-8 going BEEP since 19/3/2004
Posted: Fri Feb 24, 2006 1:29 pm Post subject: |
I've just had an idea.
I can't do it myself right now, because I cannot upload to my webspace from work, but why doesn't someone put their own (working) splash screen up on the web somewhere, without changing it at all (ie not changed to jpg to be able to see it on a forum, no name change to be able to post several in the same place - just a single, working "splash.bmp"
Then post a link here, and anyone with this problem could be directed to it to try, or even have it emailed to them off-list. |
Posted: Fri Feb 24, 2006 8:28 pm Post subject: |
old boy just sorted me out
huge thanks.
don't actually know what was different about it.
maybe it was small, not far away _________________ RX-8 going BEEP since 19/3/2004
Posted: Mon Feb 27, 2006 1:28 pm Post subject: |
Problem was as follows:
THE IMAGE MUST BE 72 DOTS PER INCH ISH.
The images I was trying to use had higher dpi and therefore need reformating to 72dpi for them to work.
Aldwinian Occasional Visitor
Joined: Feb 28, 2006 Posts: 4 Location: Manchester UK
Posted: Wed Mar 01, 2006 5:34 pm Post subject: |
I had the same problem.
I just removed the .bmp at the end(as mentioned before).
Just name it: splash
Hope this helps. |
Posted: Wed Mar 01, 2006 6:14 pm Post subject: |
I'm saying nowt...... |
