SJP Occasional Visitor
Posted: Fri Feb 24, 2006 10:23 am Post subject: i3 POI's |
Hi, I got one of the heavily discounted i3's earlier this week, and I am having a few problems with POI's. Other than that its an excellent product, none of the reception problems I've read about (I'm, sure that reception improved when I updated the firmware though!)
Here are my queries about POI's and the POILoader (2.2.1)
Can two (or more) files of POI's be loaded at one time? When I load a second file I seem to loose the first, and I'd like different proximity alert ranges for each set.
Can one of the deafult i3 icons be assigned to a new set of POI's, or do you have to configure your own new .bmp icon?
Can you access the user-POI data from the menus in the same way as you can the in-built POI data (e.g. set a user POI as a destination).
Thanks for your help! |
Posted: Fri Feb 24, 2006 10:43 am Post subject: |
Quote: | Can two (or more) files of POI's be loaded at one time? When I load a second file I seem to loose the first, and I'd like different proximity alert ranges for each set. |
Load them all together in one go.
Quote: | Can one of the deafult i3 icons be assigned to a new set of POI's, or do you have to configure your own new .bmp icon? |
You need to load the icons with the POI files. Both must have exactly the same name.
Quote: | Can you access the user-POI data from the menus in the same way as you can the in-built POI data (e.g. set a user POI as a destination). |
Yes it's under Custom items. |
Posted: Fri Feb 24, 2006 11:36 am Post subject: |
Fantastic!
Thanks a lot, re-loading the older POI files along with the new one works a treat.
I also notice that you can set proximity alerts for each individual POI file in sequence too, just what I wanted!
I can't believe I missed the Custom Points, I'd looked through the list numerous times!
Thanks again.
Any idea how many POI's the i3 can handle (I have a 256Mb card in it)?
Finally, can the Transflash card be backed-up easily from the i3 or do I need a compatible card-reader? |
ride4smilesjonny Regular Visitor
Posted: Fri Feb 24, 2006 12:03 pm Post subject: |
SJP wrote: | Fantastic!
Welcome SJP - ive got over 35000 on mine and i dare say theres room for many many more, as for backing up the TFcard yes you will need a readers as you will notice the i3 dosent show in 'my computer'
Hope this helps! _________________ **********************************
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-) |
Posted: Fri Feb 24, 2006 12:35 pm Post subject: |
My most recent card-reader lists:-
MMC : Normal-MMC / MMC-II(RS) / T-Flash
....so I'm hopefull it will read/backup the card.
I'm up to 32,000 POI's thus far, I guess the i3 is a little more highly specified than my old Garmin E-Trex Vista with a 500 point capacity!
Has anyone tried enabling WAAS to improve accuracy of location? If so, does it work any better, or does a reduction in signal strength offset any benefit? |
Aitch2 Regular Visitor
Joined: Jan 22, 2006 Posts: 226 Location: South Coast, UK
Posted: Fri Feb 24, 2006 2:42 pm Post subject: |
Yes - I use WAAS (actually EGNOS in the EU) - and it does seem more accurate to me...
Aitch _________________ Find Somewhere Else 090407: www.marillion.com |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15389 Location: Bradford, West Yorkshire
Posted: Fri Feb 24, 2006 2:49 pm Post subject: |
i use EGNOG if i'm powered by the fag-lighter, if i'm on battery's then i leave it off. to be honest i don't think there's much difference cos the i3 'locks on' to the nearest road anyway.
MaFt |
