Pocket GPS World :: View topic - n35 plug
n35 plug
grantson
PostPosted: Sat Feb 18, 2006 2:42 pm    Post subject: n35 plug Reply with quote
hi guys posibly not the right place to post this but i wonder if some1 can help me out.. the port on the bottom of my n35 has always been a little loose when connected to the pc but not to bad. ive just been adjusting the cradle in the car and managed to bend the charger against the dash now the charger has to be held in to make a contact Sad is there any was to sort this or is it time to dig the receipt out and try for a waranty claim ? Sad
www.road-racer.co.uk
cruising through the heart of scotland
MikeyF
PostPosted: Mon Feb 20, 2006 5:23 pm    Post subject: damage Reply with quote
Do you know which bit is actually damaged.
1. The connector on the Acer - Possible claim
2. The multiplug that conects to the acer - Try your PC connector
3. The car power connector which connects to the main connector.
Option 2 & 3 you should be able to sort relatively cheaply with a new lead - check ebay.co.uk there is a car charger lead there for 1p at the moment.
Mikey
Mikey
_______________________________________
Acer N35
Tomtom ver 6.010(7720)
Tomtom map UK & IE Plus v675
jimbo_hippo
PostPosted: Mon Feb 20, 2006 5:59 pm    Post subject: Reply with quote
Its the daftest design for a car based PDA I've seen! Makes you run it in landscape! My other half's one was ok in her 5 series because it hung over the dash but in a hire car recently it was impossible! Landscape isn't my choice for SatNav but it was the only way without damaging the connector.
Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim
MikeyF
PostPosted: Wed Feb 22, 2006 1:01 pm    Post subject: N35 Reply with quote
Jimbo,
You been out drinking or just got your posts confused. Rolling Eyes
Your responce doesn't relate to the question, and furthermore the Acer N35 does not work in landscape.
Stay off the drink when posting !! Laughing Out Loud :D
Mikey
Acer N35
jimbo_hippo
PostPosted: Wed Feb 22, 2006 5:22 pm    Post subject: Reply with quote
Hey cheeky! I gave up both drinking AND smoking in the last 2 months! :-)
I see you're point but you're half wrong, half right.
I am refering to the connecter to power the PDA in the car. Its stupid because it adds about 2.5 inches to the bottom of your PDA and means that if you don't have the convenience of being able to overhang it, you must position it somewhere up around your rear-view mirror!!! (OK I exagerate but you see my point)
And you're correct that N35 doesn't support landscape......... BUT ...... Tom Tom does in the software even on an N35. My GF had a 'mare with Destinator 3 and bought TT Nav5 instead.
So stick that in yer pipe and smoke it! Laughing Out Loud :-)
Tom Tom GO 720
Holux GPSslim
jimbo_hippo
PostPosted: Wed Feb 22, 2006 5:26 pm    Post subject: Reply with quote
and the connecter to power the PDA in the car is the same as the one to connet to the PC hence the discussion. Now where's that whisky I hid some weeks ago?
Tom Tom GO 720
Holux GPSslim
TheRock
PostPosted: Wed Feb 22, 2006 6:09 pm    Post subject: Reply with quote
Jimbo was not drinking at all. The n35 does support landscape.
The firmware update to WM2003SE (with landscape support and a from 1MB to 12MB increased ROM-storage) can be found here:
ftp://ftp.support.acer-euro.com/handheld/n35/osimage/
1. update bootloader
2. update osimage
flash instructions:
Please follow the below procedures for n35 image flash.
1.Make sure you have a SD card that can be detected by n35. The SD cards that can be detected are: (1) Apacer 128/256/512MB (2) Toshiba 256MB (3) SanDisk 64/512MB
2.Copy all the OS image files to the SD card’s root directory.
3.Switch the hard reset switch to the left, and insert the SD card.
4.Make sure the AC is applied to n35.
5.Press and hold the power button, then switch the hard reset switch to the right.
6.The LCD screen will become all white. Release the power button after 5 seconds.
7.Wait for an orange progress bar to appear. (It might take about 3 minutes).
8.n35 will reboot itself when flash is done.
Note: if you fail to have an orange progress bar when flash, please make sure you have correctly copied all the necessary image files, and then repeat from step 3.
D7
loox n500
jimbo_hippo
PostPosted: Wed Feb 22, 2006 6:13 pm    Post subject: Reply with quote
Rock, you never cease to amaze me! Thanks for that.
Tom Tom GO 720
Holux GPSslim
allmen
PostPosted: Thu Feb 23, 2006 2:26 am    Post subject: Reply with quote
How do you change from portrait to landscape once the upgrade is done. I bought my N35 lastyear and on checking OS version found it to be V4.2 ; the revision date 24/11/2004; the rom version; 1.40.32; bootloader version: 2.1 This seems to compare with the details of the update but I cannot see where to switch between landscape and portrait.
TheRock
PostPosted: Thu Feb 23, 2006 8:29 am    Post subject: Reply with quote
For landscape you need rom version 2.10.12
D7
loox n500
allmen
PostPosted: Fri Feb 24, 2006 1:33 am    Post subject: Reply with quote
Are you creating a hard reset when you follow the instructions therebye losing all the information you have on the PDA?
When you say "copy all the OS image files to the SD cards root directory" is this only from the n35_sdv1.40.32_wwe.zip?
TheRock
PostPosted: Fri Feb 24, 2006 2:05 pm    Post subject: Reply with quote
All data will be deleted by flashing the PDA.
My advice would be not to perform the flashing, if you are not 100% certain what you are doing.
First you have to update the bootloader. So copy the SD-folder-files of n35_SE_Eboot 6.2.rar to the root of the SD-card and perform the flash.
Second you can update the OS. Copy the files of n35_SE_v2.10.12_WWE_SD.rar to the root of the SD-Card and perform the flash.
D7
loox n500
