Pocket GPS World :: View topic - Splash again..
Splash again..
Juey
PostPosted: Thu Feb 23, 2006 7:12 pm    Post subject: Reply with quote
no extra bmps
version 5.201 - if thats what you mean by 'firmware'
RX-8 going BEEP since 19/3/2004
TomtomGo going Mooooooo since 8/9/2004
Juey
PostPosted: Thu Feb 23, 2006 7:15 pm    Post subject: Reply with quote
I'm using one of those images now - the mazda badge
saved it as a bmp file called 'splash'
dragged it into tomtomgo (e)
no joy
blank screen on powr up/down
gazza1
PostPosted: Thu Feb 23, 2006 7:37 pm    Post subject: Reply with quote
rotated it?
Juey
PostPosted: Thu Feb 23, 2006 7:42 pm    Post subject: Reply with quote
yup.
Father ted: "Now Dougall I want you to concentrate very hard, these cows (pointing to toy plastic cows on the table) are very small, those cows (points out of the window) are far away"
Its a tomtomgo classic if that makes any difference Question
gazza1
PostPosted: Thu Feb 23, 2006 7:45 pm    Post subject: Reply with quote
Never had any problems on my classic. I'm stumped. Can't see the problem, maybe somebody else has any ideas?
PostPosted: Thu Feb 23, 2006 7:48 pm    Post subject: Reply with quote
Jeeeezus!
It needs to be called splash.bmp!!!!!
Juey
PostPosted: Thu Feb 23, 2006 7:51 pm    Post subject: Reply with quote
tried that, doesn't work either
gazza1
PostPosted: Thu Feb 23, 2006 7:52 pm    Post subject: Reply with quote
I was assuming that he had already read that on your previous post.
PostPosted: Thu Feb 23, 2006 8:51 pm    Post subject: Reply with quote
Sorry, stressful day....
Juey
PostPosted: Fri Feb 24, 2006 12:38 pm    Post subject: Reply with quote
is it because I 'replaced' the original tomtom splash
ie is their some sort of coding that has been deleted that was in the original splash file?
PostPosted: Fri Feb 24, 2006 1:29 pm    Post subject: Reply with quote
I've just had an idea.
I can't do it myself right now, because I cannot upload to my webspace from work, but why doesn't someone put their own (working) splash screen up on the web somewhere, without changing it at all (ie not changed to jpg to be able to see it on a forum, no name change to be able to post several in the same place - just a single, working "splash.bmp"
Then post a link here, and anyone with this problem could be directed to it to try, or even have it emailed to them off-list.
Juey
PostPosted: Fri Feb 24, 2006 8:28 pm    Post subject: Reply with quote
old boy just sorted me out
huge thanks.
don't actually know what was different about it.
maybe it was small, not far away Embarassed
Juey
PostPosted: Mon Feb 27, 2006 1:28 pm    Post subject: Reply with quote
Problem was as follows:
THE IMAGE MUST BE 72 DOTS PER INCH ISH.
The images I was trying to use had higher dpi and therefore need reformating to 72dpi for them to work.
Rolling Eyes
Aldwinian
PostPosted: Wed Mar 01, 2006 5:34 pm    Post subject: Reply with quote
I had the same problem.
I just removed the .bmp at the end(as mentioned before).
Just name it: splash
Hope this helps.
PostPosted: Wed Mar 01, 2006 6:14 pm    Post subject: Reply with quote
I'm saying nowt...... Crying
Page 2 of 3
