grantson Occasional Visitor
Posted: Sat Feb 18, 2006 2:42 pm Post subject: n35 plug |
hi guys posibly not the right place to post this but i wonder if some1 can help me out.. the port on the bottom of my n35 has always been a little loose when connected to the pc but not to bad. ive just been adjusting the cradle in the car and managed to bend the charger against the dash now the charger has to be held in to make a contact is there any was to sort this or is it time to dig the receipt out and try for a waranty claim ? ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ www.road-racer.co.uk
cruising through the heart of scotland |
MikeyF Regular Visitor
![](modules/Forums/images/avatars/1596224201433c80f3e079b.jpg)
Posted: Mon Feb 20, 2006 5:23 pm Post subject: damage |
Do you know which bit is actually damaged.
1. The connector on the Acer - Possible claim
2. The multiplug that conects to the acer - Try your PC connector
3. The car power connector which connects to the main connector.
Option 2 & 3 you should be able to sort relatively cheaply with a new lead - check ebay.co.uk there is a car charger lead there for 1p at the moment.
Mikey _________________ Mikey
_______________________________________
Acer N35
Tomtom ver 6.010(7720)
Tomtom map UK & IE Plus v675 |
jimbo_hippo Frequent Visitor
![](modules/Forums/images/avatars/21077135774339845938047.gif)
Posted: Mon Feb 20, 2006 5:59 pm Post subject: |
Its the daftest design for a car based PDA I've seen! Makes you run it in landscape! My other half's one was ok in her 5 series because it hung over the dash but in a hire car recently it was impossible! Landscape isn't my choice for SatNav but it was the only way without damaging the connector. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
Posted: Wed Feb 22, 2006 1:01 pm Post subject: N35 |
Jimbo,
You been out drinking or just got your posts confused.
Your responce doesn't relate to the question, and furthermore the Acer N35 does not work in landscape.
Stay off the drink when posting !! :D _________________ Mikey
Acer N35
Posted: Wed Feb 22, 2006 5:22 pm Post subject: |
Hey cheeky! I gave up both drinking AND smoking in the last 2 months! :-)
I see you're point but you're half wrong, half right.
I am refering to the connecter to power the PDA in the car. Its stupid because it adds about 2.5 inches to the bottom of your PDA and means that if you don't have the convenience of being able to overhang it, you must position it somewhere up around your rear-view mirror!!! (OK I exagerate but you see my point)
And you're correct that N35 doesn't support landscape......... BUT ...... Tom Tom does in the software even on an N35. My GF had a 'mare with Destinator 3 and bought TT Nav5 instead.
So stick that in yer pipe and smoke it! :-) _________________ Tom Tom GO 720
Holux GPSslim |
Posted: Wed Feb 22, 2006 5:26 pm Post subject: |
and the connecter to power the PDA in the car is the same as the one to connet to the PC hence the discussion. Now where's that whisky I hid some weeks ago? _________________ Tom Tom GO 720
Holux GPSslim |
TheRock Regular Visitor
Posted: Wed Feb 22, 2006 6:09 pm Post subject: |
Jimbo was not drinking at all. The n35 does support landscape.
The firmware update to WM2003SE (with landscape support and a from 1MB to 12MB increased ROM-storage) can be found here:
ftp://ftp.support.acer-euro.com/handheld/n35/osimage/
1. update bootloader
2. update osimage
flash instructions:
Please follow the below procedures for n35 image flash.
1.Make sure you have a SD card that can be detected by n35. The SD cards that can be detected are: (1) Apacer 128/256/512MB (2) Toshiba 256MB (3) SanDisk 64/512MB
2.Copy all the OS image files to the SD card’s root directory.
3.Switch the hard reset switch to the left, and insert the SD card.
4.Make sure the AC is applied to n35.
5.Press and hold the power button, then switch the hard reset switch to the right.
6.The LCD screen will become all white. Release the power button after 5 seconds.
7.Wait for an orange progress bar to appear. (It might take about 3 minutes).
8.n35 will reboot itself when flash is done.
Note: if you fail to have an orange progress bar when flash, please make sure you have correctly copied all the necessary image files, and then repeat from step 3. _________________ D7
loox n500 |
Posted: Wed Feb 22, 2006 6:13 pm Post subject: |
Rock, you never cease to amaze me! Thanks for that. _________________ Tom Tom GO 720
Holux GPSslim |
allmen Occasional Visitor
![](modules/Forums/images/avatars/gallery/wings2.jpg)
Posted: Thu Feb 23, 2006 2:26 am Post subject: |
How do you change from portrait to landscape once the upgrade is done. I bought my N35 lastyear and on checking OS version found it to be V4.2 ; the revision date 24/11/2004; the rom version; 1.40.32; bootloader version: 2.1 This seems to compare with the details of the update but I cannot see where to switch between landscape and portrait. |
Posted: Thu Feb 23, 2006 8:29 am Post subject: |
allmen wrote: | How do you change from portrait to landscape once the upgrade is done. I bought my N35 lastyear and on checking OS version found it to be V4.2 ; the revision date 24/11/2004; the rom version; 1.40.32; bootloader version: 2.1 This seems to compare with the details of the update but I cannot see where to switch between landscape and portrait. |
For landscape you need rom version 2.10.12 _________________ D7
loox n500 |
Posted: Fri Feb 24, 2006 1:33 am Post subject: |
Are you creating a hard reset when you follow the instructions therebye losing all the information you have on the PDA?
When you say "copy all the OS image files to the SD cards root directory" is this only from the n35_sdv1.40.32_wwe.zip? |
Posted: Fri Feb 24, 2006 2:05 pm Post subject: |
All data will be deleted by flashing the PDA.
My advice would be not to perform the flashing, if you are not 100% certain what you are doing.
First you have to update the bootloader. So copy the SD-folder-files of n35_SE_Eboot 6.2.rar to the root of the SD-card and perform the flash.
Second you can update the OS. Copy the files of n35_SE_v2.10.12_WWE_SD.rar to the root of the SD-Card and perform the flash. _________________ D7
loox n500 |
