Pocket GPS World :: View topic - BT position error - time lag?
mogman
PostPosted: Mon Feb 20, 2006 2:02 pm    Post subject: BT position error - time lag? Reply with quote
I'm using TTN5 on an Ipaq3970 with a Holux GPSlim236. I used to use a wired GPS receiver. Since using the BT I have noticed an error of 1-200metres between the display and what is "real". I don't remember this on the wired system. Any ides? and is there a cure? It may be a time lag as when the car is stationary it seems to be accurate.
peterc10
PostPosted: Mon Feb 20, 2006 6:06 pm    Post subject: Reply with quote
are you finding the scrolling of the map is very jerky as well? If so it is probably because your system is running out of memory and TT is not updating the display quickly enough.
Suggest you hide your POIs as that is often the cause of lack of memory and see if that improves it. The warnings for POIs will still come up.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
22.064 (26 Jun 24)
