grayus Regular Visitor
Joined: Sep 05, 2005 Posts: 106 Location: Staffs Moorlands
Posted: Sat Feb 18, 2006 2:04 am Post subject: wifi on Ipaq 2210PDA |
Can anyone recommend a wifi card for my Ipaq 2210 PDA that is easy to install to get onto the internet with,I have been looking on ebuyers web site and price wise there card seems good value for 25 notes, if anyone has a 2210 up and running with a wifi set up i would appreciate some advise thanks;
Ipaq 2210 rikline 6010 rec. amplified mount |
Posted: Sat Feb 18, 2006 10:29 am Post subject: |
I have used these in the past http://www.socketcom.com/product/WL6004-322.asp Not on the exact Ipaq you have - easy to set-up/ configure etc, only problem is the cost, they are dearer than most alternatives. One other thing to bear in mind is the battery life of the PDA will take a hit when using one of these devices, typically 30% less time off a full charge compared with a non WIFI CF equipped PDA - Mike |
Posted: Sat Feb 18, 2006 1:20 pm Post subject: wifi |
Thanks Mike I must admit i did not think that the discharge rate is so high, I thought low consumption on the Ad meant just that. |
Savin Occasional Visitor
Posted: Wed Mar 29, 2006 12:42 pm Post subject: Re: wifi on Ipaq 2210PDA |
grayus wrote: | Can anyone recommend a wifi card for my Ipaq 2210 PDA that is easy to install to get onto the internet with,I have been looking on ebuyers web site and price wise there card seems good value for 25 notes, if anyone has a 2210 up and running with a wifi set up i would appreciate some advise thanks;
I recently bought the linksys wcf54g compact flash card from pixmania. Has really good connection speed and supports both 11b & 54G. Admited i'm using it with an ACER N10 but if works with that then it should work with anything
It is quite pricey though at roughly £65.00. I would strongly suggest it though!
Darren _________________ Acer N10....yeah I know, but it does the job!!
Sysonchip Compact Flash with external patch antena (Works a treat)
Brodbit Mount (the only dedicated N10 mount available)
512Meg intergral fast (80X) SD card
TomTom 5
Snooper S5-R & Cheetah active Sa |
