dmahon Occasional Visitor
Posted: Fri Feb 17, 2006 10:15 pm Post subject: Help - lost my 7 digit postcodes when upgrading to 5.21 |
I'm running TomTom 5.21 on an iPAQ.
Today I entered a postcode and found that my TomTom 5 seems to have reverted to part postcodes rather than full 7 digit postcodes. I don't recall using postcodes since the upgrade to 5.21 - previously (after creating the tomtom folder) I had full postcodes working fine.
I've had a look through the iPAQ and the tomtom folder is still there in the root of the SD card, but I can't easily see the ZIP folder that should contain the postcodes.
Where should this folder/file be?
Can I just install the ZIP folder from the CD on its own (I upgraded from tomtom 3) or do I have to reinstall the whole thing again, possibly loosing my favourites? |
tcepser Regular Visitor
![](modules/Forums/images/avatars/129872160643e8e6b423408.jpg)
Joined: Jan 30, 2006 Posts: 76 Location: North Wales, UK
Posted: Fri Feb 17, 2006 11:16 pm Post subject: |
I know its a different way but when you click Navigate to..., then press the Right arrow button, there should be a postcode thing there. You can do full postcode searches there if I remember correctly.
Sorry if this hasnt helped but this is the way I do my full postcode searches. _________________ Tcepser
O2 XDA Mini S
256 Mini SD Card
Tomtom Navigator 5 (Great British Map)
BT GPS Receiver |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Fri Feb 17, 2006 11:40 pm Post subject: |
You should be able to install the Zip Folder from the Map CD.
If you go, via the menu, to the Install GB Map, there should also be an Install Postcodes Option. _________________ Richard
jongs Occasional Visitor
Posted: Sat Feb 18, 2006 1:12 am Post subject: |
you just need to put the zip folder into the "my documents" on the pocket pc device.
that shoudl do it!
Jon |
Tommy3090 Regular Visitor
![](modules/Forums/images/avatars/gallery/simpsons22.jpg)
Joined: May 08, 2005 Posts: 113 Location: Bolton, Lancashire
Posted: Sat Feb 18, 2006 1:29 am Post subject: |
Thanks Oldboy, I was having the same trouble myself.
It was driving me crazy :D
Loaded the zip file onto my sd card works a treat.
Thanks again
Stuart _________________ HTC Desire S - Vodafone
Android 4.0.4
TT Ver 1.0 (1072278)
Western Europe map version v895.4453
PGPSW Camera Alert |
TuurG Frequent Visitor
![](modules/Forums/images/avatars/350681644c94264ae694.jpg)
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Sat Feb 18, 2006 1:43 pm Post subject: |
jongs wrote: | you just need to put the zip folder into the "my documents" on the pocket pc device.
that shoudl do it!
Jon |
no need to put on internal memory. Only reason that that also works, is that there is a TomTom folder in My Documents as well. _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
