foley Occasional Visitor
Posted: Mon Feb 13, 2006 10:31 pm Post subject: Getting TomTom5 to work on my PDA |
Hi Guys,
I'm new on here, treat me gently :D
I've got an Orange SPV M500 loaded with TomTom5 and a Holox BT 321 GPS receiver. The GPS receiver appears to be working ok and is flashing to indicate that it's locked on ok. The PDA is picking up the bluetooth signal from the gps receiver but TT is not recognising it. I've tried to manually configure the GPS receiver to TT but the TT sotware doesn't give me a bluetooth serial port option, only infra red or serial cable.
Any ideas? |
dksbbs Occasional Visitor
Joined: Feb 18, 2004 Posts: 23 Location: Chester, Cheshire, UK
Posted: Tue Feb 14, 2006 2:42 am Post subject: |
Try the following
Go to
Preferences
GPS Status
Configure
Select Other NMEA GPS baud rate 38400
Bluetooth Serial Port Com6
Works on my M1000
Dave |
Posted: Tue Feb 14, 2006 10:48 am Post subject: |
Thx for the reply Dave.
When I get to the last bit, selecting a COM port, I only get the option of infra red or serial cable ports and no COM 6. |
peterc10 Frequent Visitor
Posted: Tue Feb 14, 2006 8:09 pm Post subject: |
Choose one of the serial cable ports (I know you have BT but don't forget this is tom tom logic at work) and try it. If that one does not work try the other. You may also need to experiment with the BAUD settings - generally better to start low and work up. _________________ Peter
HTC Sensation
Copilot for USA
alix776 Pocket GPS Moderator
Posted: Tue Feb 14, 2006 8:40 pm Post subject: |
might be a silly question but have yo paired the receiver you need to select other bt gps then com6
first on the pda go to the bluetooth manager then select new device/ partnership then search for the gps and then select thegps put in a passkey of 0000 the start tomtom go to the gps menu select other bt gps then com6 baud rate 38400 give it a second and see if it works
if that doesn't work then reinstall the tomtom navigator application after removing it first _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed Feb 15, 2006 12:30 pm Post subject: |
Thx for the help guys.
Yes I've paired the PDA to the GPS.
I don't get the option of COM6 on my PDA, I don't get any bluetooth options.
I should be geting these options:
GPS is connected to:
USB Cable
Serial cable on SP2
COM3
Native IR
Serial cable on COM1
Bluetooth Serial Port ....
But the only options I get are these:
Infrared Port
COM9
COM2
Serial Cable on COM1
COM4
COM5 |
Posted: Wed Feb 15, 2006 1:35 pm Post subject: |
try removing tomtom from the pda soft reset then try reinstalling it _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Wed Feb 15, 2006 1:41 pm Post subject: |
Will give it a go this afternoon.
Mike |
Posted: Wed Feb 15, 2006 8:13 pm Post subject: |
Tried removing TT from the PDA, soft reset and reinstall but stil not working. When installing this time I noticed this message -
The program you have installed may not display properly because it was designed for a previous version of Windows Mobile Software.
Could this be the root of my problem? |
Posted: Thu Feb 16, 2006 12:46 am Post subject: |
Is your PDA running windows mobile 2005? If so you need to upgrade to latest version of TT - free downlaod from the Tom Tom site. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Sun Feb 19, 2006 7:51 pm Post subject: |
Still no joy.
I'm running Windows 2003. |
Posted: Sun Feb 19, 2006 9:24 pm Post subject: |
are you sure its tomtom5 as tt5 will still run on 2002 machine you shouldnt be getting that message _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
pointything Occasional Visitor
Joined: 24/07/2003 08:59:36 Posts: 2 Location: United Kingdom
Posted: Mon Feb 20, 2006 9:40 am Post subject: |
Just before you go following the above link bear in mind what device you have (SPV M500), the link above is for a different unit (SPV M5000), so the advice there might not be too much use - Mike |
Posted: Mon Feb 20, 2006 10:14 am Post subject: |
Oooops, very sorry. I should not read forums early in the morning. I thought this was about the M5000
Pointy |
