Pocket GPS World :: View topic - Can you get a 2.5m in car power cable for a IpaqRX3715?
stevez
PostPosted: Tue Feb 14, 2006 3:16 pm    Post subject: Can you get a 2.5m in car power cable for a IpaqRX3715? Reply with quote
I need a 2.5m (non coiled) in car power/charge cable for an Ipaq RX3715. Does anyone know where I might get something like this?
AllyCat
PostPosted: Wed Feb 15, 2006 12:23 am    Post subject: Reply with quote
Hi Steve,
Well, I put "Ipaq RX3715 car cable" in eBay and came up with (amongst several others):
http://cgi.ebay.co.uk/IPAQ-3715-RX3715-3417-RX3417-USB-CABLE-CAR-CHARGER_W0QQitemZ5864610018QQcategoryZ58543QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That particular cable is only 4 feet long, but you could add (say) a 1.2 metre USB "extension" cable (NOT a printer cable), which I've even seen in £1 shops.
Also good for special interface cables is pc-mobile.net (they have a section on this forum) although I doubt they can offer that length of cable.
Cheers, Alan.
Pc-Mobile
PostPosted: Wed Feb 15, 2006 11:08 am    Post subject: Reply with quote
You probably will not find a 2.5m cable.
But as previous member pointed out, you can use an extension, depending on your original source.
If you use a USB charger as above, you know that you can use an USB extension cable.
If you are using a car adapter with the universal (4.0/1.7) plug you can use an extension for that but that may be a bit difficult to find.
So USB (such as your own sync/charge cable) is the easiest option.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.063 (19 Jun 24)
