Pocket GPS World :: View topic - Windows Mobile 5 and tomtom 5 compatable?
walms
PostPosted: Fri Dec 09, 2005 7:38 pm    Post subject: Windows Mobile 5 and tomtom 5 compatable? Reply with quote
I'm considering upgradeing my hx4700 to the new windows mobile version 5, is it compatable with tomtom 5 yet? Any one using it??????
Whilst i'm here, my brother wants the new Jas Jar.... anyone using it with tomtom 5 yet? anygood?????
thanks all
Merry xmas ( must be near enough to say that now!?)
PostPosted: Fri Dec 09, 2005 8:08 pm    Post subject: Reply with quote
TomTom works fine under WM2005, even better with the new release 5,2 as it will also load onto the machine via the required Active Sync 4,0. I use it on my Exec and there is no problem with it, if you are looking at upgrading the IPAQ-4700 to WM2005 then as far as I know it won't be officially available until around end of March next year.
If you load up a Beta release then best of luck as there is no way of knowing that it will be stable.
There is an issue with Dell X50V machines upgraded to WM2005 that wipes the battery out even when selected off, so be wary as yet unless the machine supplier offers the code (in the Dell case they obviously got it wrong). - Mike
sparkyweb
PostPosted: Mon Feb 13, 2006 5:41 pm    Post subject: Reply with quote
Hi Guys,
A colleague has just purchased an Exec, and wants to run TTN on it, however all the suppliers are not showing compatability with TTN5.
He rang global positioning who confirmed this.
I assume that it does work, as Mike has said he is using it. Is it easy to set up??
TIA
Sparky
PostPosted: Mon Feb 13, 2006 5:44 pm    Post subject: Reply with quote
Sparky, The Exec will run TomTom Navigator5,21 with no problems at all, this is the specific version you need as it includes the ability to install to a WM2005 device, which the earlier versions couldn't do. You will need a Bluetooth GPS unit as you cannot use a cable connected GPS unit with the Exec - Mike
sparkyweb
PostPosted: Mon Feb 13, 2006 5:47 pm    Post subject: Reply with quote
Hi Mike,
Thanks for a prompt reply, the only reason for asking is that another colleague had purchased a Mio 2*** (can't remember the exact model) with WM5 on it, and TT did not work at all. The friendly people at global positioning did sort it out for him though (with lots of tech support and a work around).
Wanted to check that it was a blip as far as the Mio was concerned.
Mark
