Pocket GPS World :: View topic - Problem with POI's on icn520 - please help
stevedurrant
PostPosted: Sun Feb 12, 2006 1:02 am    Post subject: Problem with POI's on icn520 - please help Reply with quote
Hi fellas new user here with an issue that hopefully somebody can help with.
I have installed several POI's on my icn they are there ok, everything seems hunky dory. However i started noticing that i was not getting icons on screen when i should have been. So i did a search and realised that i only have the first 99 locations wihin each POI(in alphabetical order), the problem is that there is normally more than 99 locations(Mcdonalds for instance has nearly 900)
I've tried everything i can think of, the POI's were installed using POI editor, i only have about a dozen loaded, all of the .csv files i used have hundreds of locations, but in each case only the first 99 locations are searchable.
Am i missing something simple? or is this a snag with my software?
Thanks for taking time to read this post, any help will be greatly appreciated.
Steve
CeeJay
PostPosted: Sun Feb 12, 2006 2:18 am    Post subject: Reply with quote
Hi Steve.
Welcome to the mad house. :D
Just one question I can think of, did you insert a bitmap before you installed to device?
You will find that the 520 only displays the first 99 POI's in a list, but, trust me, they are normally all in there.
Easy way to check is do this:-
Go to - Address or POI - Find Point of interest - Selct POI.
When you're there, select any of your POI's you wish to check, (eg. McDonalds) then click on any letter on the keyboard display and it will give you up to 99 of your points of interest at locations starting with that letter.
It's a Navman thing. Confused
Alternatively zoom out all the way so you see all of GB, pick a point on the map and then zoom in and have a look round for your POI's.
I think you'll find they are all there, if not just holler!
Hope this helps.
CJ.
22.064 (26 Jun 24)
