Pocket GPS World :: View topic - GlobalSat BT338 vs HOLUX GR-230?
therock003
PostPosted: Sat Feb 11, 2006 1:54 pm    Post subject: GlobalSat BT338 vs HOLUX GR-230? Reply with quote
i want to ask you guys,what do you think of these two models.I want to get a bluetooth gps recieve fopr my mobile phone (p910i-uiq) and i'm considering one of these two,just don't know which one.
I don't know anything about gps so so far only thing clear to me,isthat both use a sirf 3 chip and the globalsat has very good battery time.Other than that i can't make any comparison and that's where i need your expertise.
PostPosted: Sat Feb 11, 2006 3:27 pm    Post subject: Reply with quote
You need to re-check your information the BT338 does contain the SiRF-III chipset, but the GR-230 is SiRF-II - the Holux GPSlim-236 is the device you should be comparing as that contains the correct chip set - I can confirm that this Holux product is a great device.
For a revue use the following links:
GR-230 http://www.pocketgpsworld.com/holuxgr230.php
BT338 http://www.pocketgpsworld.com/bt338.php
GPSlim 236 http://www.pocketgpsworld.com/gr236.php
I hope this is of use - Mike
Edit to correct spelling (suppliers name) - Mike
therock003
PostPosted: Sat Feb 11, 2006 5:49 pm    Post subject: Reply with quote
I checked some of the reviews,but some seem to be outdated.For example the review for emtac.gets a 100 rating but it seems to be posted in 2002!
I've been advised to get one of the following:
Holux,globalsat,emtac,fortuna slim.
A)Which one do you believe i should choose?
B)Other than battery life,what other factor should i consider before i buy?
C)In the globalsat review,as a con it mentions no SBAS support?What exactly is SBAS and WAAS?
PostPosted: Sat Feb 11, 2006 8:14 pm    Post subject: Reply with quote
SBAS stands for Satellite Based Augmentation System, in short it will improve the accuracy of your position if and when available in your current location http://gpsinformation.net/exe/waas.html this covers some of your other questions, I would stick with the SiRF-III chipset equipped devices as they perform so much better, the GR-230 device you mentioned earlier is the same as my Altina GPS unit, its good but no comparison to the Holux 236 - Mike
therock003
PostPosted: Sun Feb 12, 2006 1:44 am    Post subject: Reply with quote
Other than globalsat and holux 236 are there any other sirf-3 devices i should be considering?
Between the globalsat nad Holux which one would you recommend?
