Chrome_Orange Occasional Visitor
Posted: Tue Jan 03, 2006 4:39 pm Post subject: |
Anyone got one working on an SPV M500? It's not locked to Orange if that makes a difference
TIA |
adami Occasional Visitor
Posted: Wed Feb 08, 2006 9:19 pm Post subject: SD-502 & Qtek 9090? |
Reading some bad experience with a compatibility of SD-502 in some forums I'd like to ask, if you have some experience / information about compatibility of SD-502 with Qtek 9090.
I did not find it in any compatibility list.
Roman |
MikeB Frequent Visitor
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Mike.png)
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Wed Feb 08, 2006 11:15 pm Post subject: |
That is an error on the GlobalSat site. It doesnnot work with the MDA or the M500 or other variations of the device. _________________ Mike Barrett |
AndyHK Occasional Visitor
Posted: Tue Feb 28, 2006 5:18 am Post subject: |
I've just bought an SD-502 receiver. Could one of you guys please explain how to make the device work on an hp iPaq 4700? I've installed 2 files GPSinfo.exe and GlobalSatSDGPS.exe. Both show as removable programs. GPSInfo launches. And then what? The hardware does not appear to come with an user manual of any form so I'm a bit lost as to what all the COM ports are for. I don't want it to communicate with the PC (or anything else), I just want it to find satellites. Start GPS or Cold Start appear to do nothing. The steady green light remains - well - steady!
Ideas? TIA
Andy |
hellnick Occasional Visitor
Posted: Tue Apr 11, 2006 11:53 am Post subject: |
I'm having similar problems to the last poster - unit is installed on an rx3715 using the latest driver, seems to be on Com7 and I get a static green light whenever it is plugged in. I've tried a variety of utilities but never seem able to get a fix on my position - a few times I've picked up a number of satellites but that's it.
I've left it running while sitting outside (no buildings closer than 40 feet) for more than half an hour and still nothing. Anyone got any tips?
Thanks in advance |
Posted: Tue Apr 11, 2006 3:38 pm Post subject: |
This sounds like a faulty device. If it has power which it has it should get a fix pretty quickly and a reasonably strong one at that. If you have had it outside and constantly powered for 30 minutes with no obstructions then something is very wrong. _________________ Mike Barrett |
xda Lifetime Member
![](modules/Forums/images/avatars/2206758954c7fc3ddae53f.jpg)
Posted: Fri Apr 14, 2006 2:44 pm Post subject: |
Mike, there seems to be a reliability issue with some of these SD-502 devices.
My first one worked for the best part of 3 months until for some unknown reason the SD card opened up along the seam whilst in use. It was returned and replaced with another unit.
After 3 weeks or more I have still not been able to get a data stream, even though it is installed correctly, and the green light is flashing after a couple of minutes. The SD card is seen as a GPSDisk, TomTom is on there, com port is set at 7 as was the previous one but not a single sat fix. This one has now been returned as well. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Fri Apr 14, 2006 3:35 pm Post subject: |
This is worrying. I will bring it to the attention of the GlobalSat R&D department. _________________ Mike Barrett |
xda Lifetime Member
Posted: Fri Apr 14, 2006 6:59 pm Post subject: |
Thanks Mike, it seems a few others have got SD-502's that have shown a flashing green light indicating they have a fix but no Sats showing in the various programs that should be showing a data stream, perhaps it could just be down to a faulty production batch.
Returned the last one last tuesday to Matt at Easydevices who said he had an XDA 2s to try it on so will wait and see what he comes back with. _________________ Graham.
