Pocket GPS World :: View topic - Air Vent Mounting
Air Vent Mounting
Downward
PostPosted: Tue Jan 31, 2006 10:53 pm    Post subject: Air Vent Mounting Reply with quote
Bought the additional mounting kit so I could keep the Window Sucktion mount installed permantly and the Air Vent mount installed permantly as the addition mount kit doesn't come with an extra thumb screw so you have to take it off the original window suction mount to use to connect the Tom Tom one to any other mount 8O
Anyhows how the hell do you get the clips into the air vent - It's impossible !
Kingscoop
PostPosted: Tue Jan 31, 2006 11:52 pm    Post subject: Reply with quote
I'd think twice about permanently installing the mount on the windscreen - look through some posts here and it becomes obvious that the thieves are targetting cars with sat nav mounts in the window.
Downward
PostPosted: Wed Feb 01, 2006 6:45 pm    Post subject: Reply with quote
Word of warning - The additional mount kit isn't really a kit you can use seperatly to the mount kit that comes with the TT1, Not sure if you can buy the original windscreen mount as a seperate item but £20 for the additonal mount kit is a Rip Off.
markrfc
PostPosted: Fri Feb 03, 2006 5:22 pm    Post subject: Reply with quote
Same here i bought the additional mounting kit and was really dissapointed sold it straight away and ordered a brodit mount.
porndoguk
PostPosted: Mon Feb 06, 2006 10:55 pm    Post subject: Reply with quote
have a butchers at my write up and pictures
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=33548&start=15
Downward
PostPosted: Mon Feb 06, 2006 11:43 pm    Post subject: Reply with quote
HAHA
I have a Pug 306 and I have just put the Air Vent clip there too this morning as it doesn't fit over the Central ones due to the Shape. It doesn't in the Wifes Ford Focus either.
Problem is ther is that it's not in your line of vision.
porndoguk
PostPosted: Tue Feb 07, 2006 1:12 am    Post subject: Reply with quote
Downward wrote:
HAHA
the perfect place mate, you look there at your clocks, and mirrors, not so theft viewable, and its descreet,
i took the vent out with a terminal srewdriver and then reoved the slider thingy outt the back and left, and fired it on the slot thats not a air vent mount thats actually the original bracket from the window mount just undid and found it fitted perfectly,
plus when the tom tom isnt on the bracket you can still run the vent with the big hole in the middle,
absolutely spot on!
was ded chuffed when i did it!
porndoguk
PostPosted: Tue Feb 07, 2006 1:17 am    Post subject: Reply with quote
here you go direct pics,
22.071 (03 Jul 24)
