Zylog Occasional Visitor
Posted: Sun Feb 05, 2006 10:15 pm Post subject: Ipaq 4700 + SD 502 + Bluetooth ? |
Hello all,
Could anyone tell me if It is possible to use an bluetooth earpiece with a Ipaq 4700 running a SD502 GPS receiver.
Thanking you in advance.
Peter |
StevenGourlay Frequent Visitor
![](modules/Forums/images/avatars/185987854445be6a220df05.jpg)
Posted: Mon Feb 06, 2006 3:51 pm Post subject: |
Thanks for the reply Steven, I was wondering if the bluetooth would work at the same time as the SD502. I know the SD502 uses the SD card slot but does it use bluetooth resources which may make it difficult for them to work together.
Regards. Peter |
peterc10 Frequent Visitor
Posted: Mon Feb 06, 2006 10:14 pm Post subject: |
PPC supports multiple BT connections as long as the connections are of a different protocal (or service). So you should be OK as one will be a serial port service (probably) and the other a headset service. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Tue Feb 07, 2006 12:26 am Post subject: |
Thankyou peterc10, I will go ahead and order the SD502 and see if I can find a good bluetooth earpiece.
I note your user name is the same as my real neme! |
