TonyD Frequent Visitor
Posted: Mon Feb 06, 2006 12:53 am Post subject: Warning when exceeding speed limit |
Is anyone aware of any intention to add this facility. I know it would require new data, but it doesn't seem to me that difficult to achieve. |
Posted: Mon Feb 06, 2006 12:57 am Post subject: |
As far as I know it can already do this (I use it), try change Preferences, Turn off map display, select the check box for Above a certain speed then set your desired speed, if you go over this setting the display goes dark very quickly - Mike |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon Feb 06, 2006 1:17 am Post subject: |
I think that TonyD means a warning when the posted limit is exceeded. _________________ Tim |
Posted: Mon Feb 06, 2006 10:09 am Post subject: |
Tim Buxton wrote: | I think that TonyD means a warning when the posted limit is exceeded. |
Exactly - that's why I said it would need new data. Every street (and potentially sections of a street) would need an extra attribute of speed limit. Although it's not a trivial task, once done it would be fairly stable as speed limits change less frequently than cameras. |
Posted: Mon Feb 06, 2006 10:38 am Post subject: |
I believe that Garmin Mapsource CityNavigator has this data, though I'm not sure how complete or accurate it is. It may be that TeleAtlas can also introduce it. _________________ Tim |
