Pocket GPS World :: View topic - Bad install of Iguidance
UHF
PostPosted: Thu Feb 02, 2006 4:01 am    Post subject: Bad install of Iguidance Reply with quote
I have removed and installed many times, v2.0
It keeps saying it cannot find the sound files or they are corrupt. I have extracted them. Where does the sound files go and what should I label the file they are in on my desktop computer. Map loader works fine, but without the desktop version, I cannot install to my PDA.
Please help with install.
PostPosted: Thu Feb 02, 2006 4:29 am    Post subject: Reply with quote
You can install the CAB file directy on the Pocket PC
the sounds go into a "Snd" subfolder of the main application folder - where ever you chose to install. (if you install to storage card you need to install under "\Storage Card\iNav iGuidance" else it won't work.
UHF
PostPosted: Thu Feb 02, 2006 5:18 pm    Post subject: The cab file Reply with quote
What is the name of the cab file?
I have found two but neither will run on my pda when I copied it over.
They are:
data1.cab (winzip file 461kb)
data2.cab (winzip file 27kb)
My pda says they are not a recognized/invalide file type.
UHF
PostPosted: Thu Feb 02, 2006 5:45 pm    Post subject: Reply with quote
Thank you. I got past the sound file problems, now its saying bad or corupt map data. I have found the two map data files on the cd. Where do these go?
UHF
PostPosted: Sun Feb 05, 2006 2:01 am    Post subject: Reply with quote
The problem is that everything is installing to the windows directory and never making an inav or iguadance folder. Since its installing to windows, I cannot fully/completely remove the program for a good install. I've tried windows remover (control pannel), and the inav remover and it still leaves files. I'm still trying to install it correctly. Anyone know what files I need to look for in the windows directory to remove?
PostPosted: Sun Feb 05, 2006 2:08 am    Post subject: Reply with quote
the .000 file inside the CAB has the installer blueprint - all file names and locations.
Use CabInstl to enforce a install location.
UHF
PostPosted: Sun Feb 05, 2006 2:33 am    Post subject: Reply with quote
Got it done!!!
Downloaded a trial period uninstall fixer program. It found a leftover registery file. Removed it and the program. Did reinstall, now it works fine!!! Just a bad uninstall. Thanks for your help.
23.011 (02 Jan 25)
