Mirx Occasional Visitor
Posted: Sat Feb 04, 2006 6:07 pm Post subject: TomTom Navigator 5.2 + ipaq 4150= no signal. Help please! |
Hello guys,
I have just installed and activated TomTom Navigator 5 with my ipaq 4150, however, cannot get a signal.
Whilst the GPS receiver flashes green light I keep getting the following massage: :"Waiting valid GPS signal". After about 5 minutes the GPS receiver switches itself off. Each time I switch the receiver back on, the green light will flash for another few minutes before it goes off without getting any signal.
I would much appreciate any idea why this is happening.
Thanks in advance
Mirx |
Posted: Sat Feb 04, 2006 7:31 pm Post subject: |
Welcome to the forum, Exactly which GPS unit are you trying to get to work? additional information such as this will aid others in finding a solution to your problem, a simple bit of advice is to try the set-up outside as the GPS units don't generaly work inside a house/ building, if you you have the yellow/ blue disk (top RH of the GPS status page in TomTom) spinning then it just needs a decent view of the sky, if its not spinning you have a setting incorrect - Mike |
Posted: Sun Feb 05, 2006 12:00 am Post subject: |
Thank you very much for your prompt reply Mike. You are spot on - my setting WAS wrong!
I managed to rectify the problem by visiting TT Support.
I use a wireless TT GPS MkII.
It appears that during the set up of the software, which I did indoors, my ipaq 4150 was not configured with the GPS reciever - yellow/black wheel wasn't spinning. I followed the instructions on manual configuration procedure on the TT site and my Navigator 5 now works fine.
Having browsed a little through this forum in the last few hours I am amaized with the level of knowledge and experience available to the beginers like myself. This is a truly wonderful forum!
Cheers |
