Pocket GPS World :: View topic - Trying to install Tomtom on Mediom 95900.....Stuck!!!
ferjan
PostPosted: Wed Feb 01, 2006 2:54 pm    Post subject: Trying to install Tomtom on Mediom 95900.....Stuck!!! Reply with quote
I am trying to install Tomtom on my Medion 95900 but so far I have not been able to crack the system.
I have downloaded all the information from this site on how to crack the system and then install Tomtom, somewhere I seem to be going wrong.
I have gone to explore via Activesyn and copy and paste the regedit and modified reg into the right folders but after I do a restart it just starts in the normal way, installing Medion navigator but no sign of the taskbar anywhere.
When I check via activesyn and look in the folders again there is no sign of Regedit or modified reg somehow these are not saved to the system and without these I guess I am not going to go any further hi, any thoughts on why I am not able to save these please.
Is this the right method for doing the crack....I open up the folders via activesyn then copy and paste these into the right folders then reset the 95900 is there something I am missing???.
Any help appreciated.
Hooloovoo
PostPosted: Wed Feb 01, 2006 5:26 pm    Post subject: Reply with quote
Make sure after you have copied the files you do a soft reset, not a hard reset as this will remove the files again.......
Also make sure you are putting showtaskbar.exe into \windows\startup.
ferjan
PostPosted: Wed Feb 01, 2006 7:38 pm    Post subject: Thanks Reply with quote
Thank you for the reply, I thought it said in the instructions to remove the screw from the stylus to do a reset after installing the files which is the option at the back of the unit????.
By soft reset I think you mean just turn it off and on again....I will try and see what happens.
ferjan
PostPosted: Wed Feb 01, 2006 8:06 pm    Post subject: No Good Reply with quote
To continue I have tried both methods but it did not work, when I restart the unit and look for the files I have installed they are gone so that's why it does not work any suggestions as to getting these files to stay put would be a help.
Back to the drawing board hi.
Andysue
PostPosted: Wed Feb 01, 2006 9:26 pm    Post subject: Re: No Good Reply with quote
I think you are hard reseting it. I dont have one of these but there should be a small hole somwhere to just push the end of the unscrewed pen in.
Dont you have any instructions?
Hooloovoo
PostPosted: Thu Feb 02, 2006 1:37 am    Post subject: Reply with quote
Push the end of the stylus in the little hole on the top of the unit at the left.... where it cunningly says "reset".
A hard reset (the switch on the back) clears everything back to factory settings, which is why the files are gone after you've copied them. A soft reset (the button on the top) performs a "reboot" and allows the showtaskbar.exe to run on Windows startup.
ferjan
PostPosted: Thu Feb 02, 2006 1:15 pm    Post subject: I see!!!! now Reply with quote
Once again many thanks for the help....it must be me eyes hi I was mistaken the hard reset for the reset I will now try and get it right this time, crack the system then install Tomtom hopefully.
Thanks.
crazydad
PostPosted: Thu Feb 02, 2006 8:21 pm    Post subject: Reply with quote
sort of related. ive read on many forums that people have tom tom 5 to install onto their medion/micromaxx or whatever. where do you get it from????!!?
Hooloovoo
PostPosted: Thu Feb 02, 2006 9:08 pm    Post subject: Reply with quote
Try >>here<<.
bertie_uk
PostPosted: Fri Feb 03, 2006 8:34 pm    Post subject: Reply with quote
Instruction in post:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=27735
worked for me
Bertie
Pc-Mobile
PostPosted: Sat Feb 04, 2006 4:38 am    Post subject: Reply with quote
He is trying to install a pirated copy!
Somehow something is missing or he did not do it right.
Pc-Mobile
http://pc-mobile.net/gps.htm
