Pocket GPS World :: View topic - Disable screen auto power off with destinator
guimenez
PostPosted: Tue Jan 31, 2006 12:20 pm    Post subject: Disable screen auto power off with destinator Reply with quote
hello
i'm using destinator, but after 3m the screen power off, i know that i can change in power configuration of windows mobile, but if i do that i will lost more battery power(i will forget to turn off manual). with tomtom the screen doen't power off. does anyone know how to do it in destinator
thanks
jellied
PostPosted: Tue Jan 31, 2006 2:06 pm    Post subject: Reply with quote
You can't do it in D3. I've set mine to dim the screen after 5 minutes when on power (i.e. in the car or at home in the cradle) which is usually enough for me.
You only have to touch the screen or the thumb button to get the screen to brighten again.
timanfiya
PostPosted: Tue Jan 31, 2006 4:06 pm    Post subject: Re: Disable screen auto power off with destinator Reply with quote
guimenez wrote:
hello
thanks
You can go into your settings, you will should see a backlight option in there in which you can adjust your screen brightness and time of autolight off. Or you can set it so it never goes off whilst on.
Pete
Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174
guimenez
PostPosted: Tue Jan 31, 2006 6:40 pm    Post subject: Reply with quote
thanks for replying.
i know that, but i want just do that for destinator and not forever because if i receive i msg and if i'm not seeing the mobile it will keep losting power because it has the screen on.
i hope you understand me
timanfiya
PostPosted: Tue Jan 31, 2006 9:18 pm    Post subject: Reply with quote
Sorry I'm not sure I understand what you want to do. You want power save on for destinator when it is on but not for other functions of your pocket pc??
You see I run it on a pnd so I may have a slightly different setup to you. I was talking about a settings menu in destinator, is this not what you were after? When I exit Destinator I have option to go back into destinator or change settings (I think this is called the Destinator Shell). I suppose this is the settings of my unit so you will have different. Not sure I understand myself now, sorry mate.
Pete
Goodmans GNAV10
WinCE 4.20(0)
guimenez
PostPosted: Wed Feb 01, 2006 12:37 pm    Post subject: Reply with quote
ok i try to explain.
my device after 3m goes to power safe write? it's normaly and its that what i want.
but when i start the destinator, after 3m using it, the device goes to safe power state and turn off. but if i use tomtom the system doen't go to safe power state(thats is normal). i just want to do the same for destinator
timanfiya
PostPosted: Wed Feb 01, 2006 1:29 pm    Post subject: Reply with quote
Ah I understand now. I don't really know. Have you tried altering the settings in Destinator (Backlight) or do you not have this option. You see, as I said I run OP on a PND and have a software shell that controls these setiings. I am not really sure if yours will be the same. But even if you can control the backlight settings through Destinator I would have thought your timer of 3 mins for your pocket pc would still activate.
Goodmans GNAV10
WinCE 4.20(0)
guimenez
PostPosted: Wed Feb 01, 2006 9:56 pm    Post subject: Reply with quote
thanks for replying
i don't have that menu in destinator.
and in windows i don't want to use it because i will spend more power, if i receive a ring call the mobile will be always with light on(spending power)
