kayani Occasional Visitor
Posted: Tue Dec 13, 2005 3:58 pm Post subject: ttn5 voice problem |
i have tomtom navigator 5 working on my xda2i with bt338 gps but no voice when i try to select voice message appears (you did not select a usable voice.
software ver. tomtom 5.21
please help
thankyou |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Tue Dec 13, 2005 6:02 pm Post subject: |
you need to have at least one pair of VIF/CHK files either in the application folder or in a folder called VOICES in the root of the storage card. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Dec 13, 2005 7:24 pm Post subject: |
lbendlin wrote: | you need to have at least one pair of VIF/CHK files either in the application folder or in a folder called VOICES in the root of the storage card. |
thankyou for your reply and your time i don't have the folder called voices in the root or storage card |
Posted: Tue Dec 13, 2005 7:30 pm Post subject: |
kayani wrote: | lbendlin wrote: | you need to have at least one pair of VIF/CHK files either in the application folder or in a folder called VOICES in the root of the storage card. |
i have download the new file from tomtom ver 5.2X
but still same problem |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Dec 13, 2005 8:04 pm Post subject: |
The new TTN5,2 should have created a folder called tomtom in the root of the storage card, if you still haven't got the voices folder then create it and put the voice files into it, then it should work - Mike |
Posted: Wed Dec 14, 2005 3:33 am Post subject: |
mikealder wrote: | The new TTN5,2 should have created a folder called tomtom in the root of the storage card, if you still haven't got the voices folder then create it and put the voice files into it, then it should work - Mike |
****** working thankyou thank you thank you *********
and thnak you thankyou every body thankyou
may god give you healthy and long and happy life
thankyou |
adobbing Lifetime Member
Posted: Tue Jan 31, 2006 12:22 am Post subject: |
Just had the same issue and found the cause and cure.
for some bizzarre reason tomtom deletes the dataXX.chk file of the voice file pair.
Basically each voice on tom tom has both a dataXX.chk and a dataXX.vif file, the .chk file becomes deleted.
If you create a copy of these then paste the .chk file back into the directory it was deleted, normal service is resumed !!!! |
