Pocket GPS World :: View topic - New maps available? i3
jog_on
PostPosted: Mon Jan 30, 2006 8:57 pm    Post subject: New maps available? i3 Reply with quote
I was using my i3 the other day and it went a bit strange. Firstly it had me in a completely different area of the UK but still had sattelite lock as position cursor was moving in synch with car. Then after a couple of mins an information box came up on screen stating 'New maps available now' then it recalculated itself and unit went back to normal.
Has anybody else experienced anything like this?
Aitch2
PostPosted: Mon Jan 30, 2006 9:06 pm    Post subject: Reply with quote
Running v2.70 firmware?
Aitch
Find Somewhere Else 090407: www.marillion.com
big_ash
PostPosted: Tue Jan 31, 2006 12:12 am    Post subject: Reply with quote
Not had this happen to me.
Another question, does upgrading the firmware to 2.70 upgrade the maps?
Aitch2
PostPosted: Tue Jan 31, 2006 12:43 am    Post subject: Reply with quote
No. They are completely separate things.
The firmware can be user updated using the WebUpdater app downloaded from the Garmin site.
The Navteq maps will (we are told) be updatable to v8 via (presumably) a CD from Garmin for v7 mapping owners in 'early 2006'???
I only mentioned the firmware, as my i3 came originally (from Somerfield) with v2.50 firmware - and this did exhibit some screwy mapping out of the box - with 'ghost' waypoints appearing, and sudden large deviations to position - with the described constant route recalculation also.
Updated to v2.70 - and nothing weird seen since - running v8 maps too, btw.
Aitch
jog_on
PostPosted: Tue Jan 31, 2006 8:49 pm    Post subject: Reply with quote
Aitch
Yep, it's running on v2.7. God know's why that message came up. And besides how would the unit know if there were new maps available when it only receives a GPS signal? Unless it's been pre programmed to show message on or after a certain date, but if that was the case i'm sure there'd be many other units doing same thing.
RODTROTTER
PostPosted: Wed Feb 01, 2006 12:14 am    Post subject: Reply with quote
big brother is watching 8O 8O
Trajet
PostPosted: Wed Feb 01, 2006 3:11 pm    Post subject: Reply with quote
Which is a hundred times better than wathing Big Brother.... Laughing
jog_on
PostPosted: Thu Feb 02, 2006 8:29 pm    Post subject: Reply with quote
And then today I switched my unit on and a picture of a desktop PC and i3 came up on screen with a message telling me to update turn by turn maps by using the supplied PC software. I had to switch it off and on again to get rid of the message. God knows what is going on. All very strange!
DavidEvans007
PostPosted: Fri Feb 03, 2006 1:01 am    Post subject: Reply with quote
i'm getting the same thing on mine too...
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=188874#188874
havent got a clue whats going on with it either.. so far i havent had a good days use out of it yet... it was only a bargain from Somerfield if the bloomin thing works !!
muffinhead
PostPosted: Mon Feb 06, 2006 11:24 am    Post subject: Reply with quote
Hi all
Running 2.6 firmware and went to upgarde it to 2.7. Downloaded the Wepupdater tool but I cant get this to recognise the i3 via my USB post - any I being stoopid of something?
Any help pls?
Confused
Ash10
PostPosted: Mon Feb 06, 2006 3:46 pm    Post subject: Reply with quote
I too have seen the "update maps from PC" screen a couple of times. I just ejected the TransFlash, reinserted it and wiggled it around a bit - seemed to make the problem go away for me.
smstextaddict
PostPosted: Mon Feb 06, 2006 9:06 pm    Post subject: Reply with quote
be nice if they would hurry up and release the V8 maps for the i3
Aitch2
PostPosted: Mon Feb 06, 2006 9:48 pm    Post subject: Reply with quote
Tip - eject the Transflash card (with i3 powered off 8O) and then use a normal pencil eraser (rubber variety) vigourously on the gold contacts - being careful to blow off any spare crumbs - before reinserting card.
This will remove any oxidation or other gunge from the edge contacts, and should ensure that your i3 is less likely to forget it has maps loaded...if indeed it ever suffers thus...(mine doesn't).
Aitch
missing_user
PostPosted: Mon Feb 06, 2006 10:40 pm    Post subject: Reply with quote
Do you know of the cost involved?
£80????? for each card/area
PaulB2005
PostPosted: Tue Feb 07, 2006 11:14 am    Post subject: Reply with quote
What is this about the V8 maps i see only many threads? Mine came with the V8 maps. Did Garmin announce a free upgrade to V8? Will i get a free upgrade to V9?
23.054 (28 May 25)
