Pocket GPS World :: View topic - TomTom 5 problem with pda address book
Hammer2006
PostPosted: Fri Jan 27, 2006 5:50 pm    Post subject: TomTom 5 problem with pda address book Reply with quote
Need some help guys as i cant get tt5 to work with my address book.Every time i try to navigate from my pda address book its says failed! Confused
Is there anybody else had this problem? and is there a fix?
Mikeact
PostPosted: Fri Jan 27, 2006 9:25 pm    Post subject: Re: TomTom 5 problem with pda address book Reply with quote
I could do with the answer to this as well. Everytime I hit the post code in the address book, I also get 'failed'.
Etwell
PostPosted: Sat Jan 28, 2006 8:21 am    Post subject: Reply with quote
I'm not sure if you are referring to navigate from 'Contacts'.
If so, I had a similar problem and the answer is here
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=34180
peterc10
PostPosted: Sat Jan 28, 2006 10:21 pm    Post subject: Re: TomTom 5 problem with pda address book Reply with quote
It doesn't search by postcode from the contacts list. Instead it uses city and street. See my advice in the post Etwell kindly referred to.
Peter
HTC Sensation
Copilot for USA
Hammer2006
PostPosted: Sat Jan 28, 2006 11:55 pm    Post subject: Reply with quote
Cheers for the post peter but it still wont work Sad and i did everything you said and all i get is this annoying 'failed' if i click map or navigate.
Just wondering if this is only a problem with the old/original version of tomtom 5 ??
Etwell
PostPosted: Sun Jan 29, 2006 11:41 am    Post subject: Reply with quote
I was using TT 5.2....
peterc10
PostPosted: Sun Jan 29, 2006 1:01 pm    Post subject: Reply with quote
Should work on all versions of TT5 - worked on my original TT5.0. How exactly are you trying this. The trick is to call up the contacts list and then hold the stylus on the contact until the list comes up. when it does do you have the options "navigate to" and "find on map", because they are what you need?
Exactly what message do you get when you try this - is it similar to the one that Etwell was getting (as in the other post)? If so TT is trying to find the address but can't match your fields with its database. Does this happen on all contacts? You could try a nice simple address that you know is correct and is in TT's map. Enter number street name and city as I explained previously and see if it finds it.
Peter
HTC Sensation
Copilot for USA
Hammer2006
PostPosted: Sun Jan 29, 2006 9:28 pm    Post subject: Reply with quote
I get a straight forward failed all the time even if the address is 100% correct.
I did try without a house number and got the same message as etwell "There is no matching address found, please check that fields contain the correct data"
Been fiddling with it all weekend and so far no luck Sad
Etwell
PostPosted: Mon Jan 30, 2006 1:15 am    Post subject: Reply with quote
The first line of the address needs to be the house number and the street, nothing else. No house names,commas, full stops or anything like that.
On the next line put the town,district, county etc. these can all be on one line.
Give that a try.
If you are syncing from MS Outlook there is a separate address window there. Do the same.
Good luck.
peterc10
PostPosted: Mon Jan 30, 2006 1:28 am    Post subject: Reply with quote
If you are getting that message then the programme is working but can't find your address. Have you tried entering that addresses in Outlook in the way that I suggested (making sure you have a pop up box that requires you to enter street, city etc in seperate fields) and then re-syncing the PDA? Have you tried to see if TT recognises the address when you enter it directly?
Peter
HTC Sensation
Copilot for USA
Mikeact
PostPosted: Mon Jan 30, 2006 10:50 am    Post subject: Reply with quote
And if it's; Flat 5, 28 High street ??....ignore Flat 5 because I obviously know it ?
peterc10
PostPosted: Mon Jan 30, 2006 12:27 pm    Post subject: Reply with quote
As I said in the other post TT has real difficulty with multi-entry fields. It won't read your "Flat 5 etc" example because it cannot identify the street it is looking for. Is it called "Flat" or is it called "High Street"? It will not ignore any part of the entry. Remember most computers are incredibly fast working idiots.
If you want it to work in your example then in Outlook you need to remove any reference to the Flat in the Street field (and re-sync of course). That then makes your contacts list a lot less suitable for its many other uses, such as finding what a contact's address is, printing off a label etc.
Peter
HTC Sensation
Copilot for USA
Hammer2006
PostPosted: Mon Jan 30, 2006 7:24 pm    Post subject: Reply with quote
I had another fiddle with it today and i can get my contacts to work with tt but only if i turn on tomtom manually after i get the failed message and once tt is on the contact address is there waiting for me.Seems weird why? but at least its working of sorts.
22.063 (19 Jun 24)
