Glyn Occasional Visitor
Posted: Wed Oct 05, 2005 10:10 pm Post subject: TTN3 & TTN5 - coexist on iPAQ? |
Hi there,
I think I might have asked this question before - sorry...I don't recall seeing a reply...
Is it possible to install both TTN3 and TTN5 on the same iPAQ?
I have a 2210 with TTN3 & UK maps installed and have just purchased the US map package from Expansys that includes the TTN5 program itself.
I also have the TTN5 upgrade package.
Can I just accept the installation defaults on both versions and choose which one to run or is there some 'black magic' to enable them both to co-exist on the same iPAQ?
Thanks & regards,
-=Glyn=- |
JNeail Occasional Visitor
Joined: May 17, 2005 Posts: 16 Location: Atherstone, Warks, UK
Posted: Wed Oct 05, 2005 11:04 pm Post subject: |
Hi Glyn
Yes this is entirly possible, I have both versions sucessfully setup on my iPaq HX2410. I've TTN3 installed in it's default location, and TTN5 on my CF Card. TTN3 & TTN5 maps in separate directories on my SD Card.
I had to remove TTN3 first as it insists on removing it in favour of TTN5, so remove TTN3, install TTN5 (on to a SD or CF card - not default location) then install TTN3 in default locations - Sorted!
Have fun
Regards
Jaime
PS- if your like me you'll end up still running TTN3 and TTN5 is still way too buggy for acceptable use! _________________ HP Hx2410, TTN3/5, CheckPOInt 3.2, GlobatSat BT318.
Brodit H/Wired PPC Holder Kit
New Volvo S40 SE - GPS Ariel on rear shelf
Integrated Volvo Phone (Crap - Echoes), Motorola V525, SPV E200, Nokia 6310i
>>They call me Gaget Boy!<< |
cairngorm Occasional Visitor
Posted: Tue Jan 24, 2006 3:20 pm Post subject: Activation codes (will there be a problem) |
Just about to attempt putting 3&5 together on my pda. I bought the upgrade for 5 but had to re-install 3 as I did not have enough memory for the French map on a recent trip. Put 5 back on, and now have purchased a 1GB card to cope with what I want. I seem to remember people having problems with activation codes switching between 3 and 5 and cannot find the relevant post again. I think that installing 3&5 on the same pda is ok but a problem if on a different pda. I shall wait for expert opion before I proceed.
Best Regards Cairngorm |
peterc10 Frequent Visitor
Posted: Tue Jan 24, 2006 6:22 pm Post subject: |
I think you will find that putting the upgrade version of TT5 will wipe the original version of 3. I think the licence for 3 ends when you upgrade and your number for it is no longer valid. I think if you want to run them both together, whether on one or two PDAs, you need to buy a full (rather than upgrade) version of TT5. |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Tue Jan 24, 2006 7:09 pm Post subject: |
If you use Sprite back-up software, you can load TT3, do a back-up, then hard reset or load TT5 on top, save that as a different file and then use whichever one you want by loading the appropriate back-up file. A bit servere I know but it works.
Steve |
Posted: Thu Jan 26, 2006 10:19 pm Post subject: |
Just to clarify the last post. Are both versions on the pda and you select the relevant file or are you loading each file separately from the computer. |
Posted: Fri Jan 27, 2006 1:28 pm Post subject: |
Using Sprite back-up, you only load one at a time, not side by side.
Steve |
