Pocket GPS World :: View topic - TomTom5 on MEDION MD95900
Goto page Previous  1, 2, 3
Paul80
PostPosted: Thu Jan 26, 2006 9:39 am    Post subject: Reply with quote
shaunokeefe wrote:
Thank you so much for your quality instructions !
1 last thing, is it the TomTom 5 for pocket PC as in the PDA version I should be downloading?
Many thanks
Shaun
I tryed the PDA Version but when TomTom is started The screen is corrupted and the display is on its side so that it is showing in a vertical format just like on a PDA are you sure about the version (Pocket PC/ PDA)
Dark_Mavis
PostPosted: Sat Jan 28, 2006 1:57 pm    Post subject: Reply with quote
I Installed "TomTom for Pocket PC (Win CE) - works fine.
You can change the orientation of the display in the TomTom settings.
If you have a corrupt display check that you have the correct GX.dll
suki2shoes
PostPosted: Sun Jan 29, 2006 1:35 am    Post subject: Reply with quote
big problem here. i was going through the crack as described before and the 2nd time it says to soft reset, my pda doesnt boot back up Sad
the loading bar gets to 100% and does nothing else ?
is tehre anything i can do to get back into windows.
please help really worried.
Dark_Mavis
PostPosted: Sun Jan 29, 2006 3:54 pm    Post subject: Reply with quote
what "loading bar" are you referring to? The only loading bar that I'm aware of is the one that appears when the unit is Hard reset (switch on the back) and the unit copies stuff from the memory card.
If you get stuck you can always try a hard reset and this should return the Medion to its original state.
Probably best to refer to the instruction manual - but basically, make sure the original memory card is installed, switch the unit off - then switch the little recessed switch on the back of the unit to off (for about 10 seconds) then back to on. Turn the unit on (with the power button on the front) and after a short while it should sort itself out and have reverted back to its original state.
lorri
PostPosted: Fri Apr 06, 2007 1:07 pm    Post subject: Reply with quote
Hi everyone,I am trying to put the tom tom on my 95900,done the first partwith getting the shortcuts on the desktop but when i try and put the program on it says not enought disk space on so what should i do,rub something out?
Help Lorri
plinth
PostPosted: Mon Mar 23, 2009 8:43 am    Post subject: Reply with quote
Has anybody got this to work so that they don't have to re-install the whole thing if the Medion battery goes flat?
Page 3 of 3
22.063 (19 Jun 24)
