Pocket GPS World :: View topic - Navman 510 software query!!!!
jnielow
PostPosted: Sat Jan 21, 2006 8:21 pm    Post subject: Navman 510 software query!!!! Reply with quote
Hello All,
New to site! and to navman 510 model! The sat nav came with v3 software and maps dated 2004. I am getting hold of more up to date maps, will they work ok? ie new maps older software?. Will the navman 510 run the newer smart2005 software, if so is there much benefit from the newer software?. Apart from getting the software directly from navman, has anyone got any other contacts for this software (perhaps I should not be asking !)
Clarification would be welcomed!
Thanks again
Jason :D
DRP
PostPosted: Sat Jan 21, 2006 9:14 pm    Post subject: Reply with quote
Hi.
I have had my 510 since last April it came with V3 & 2004 maps. I have been running V3.5 and the full European maps since the beginning of December. The new software is a lot more user friendly then V3. No problems with the install, but if I were you I would perform a clean up of your Navman than over writing your old software. Have a look at some of my old posts or look at the V3.5 manual, from memory I think its page 28 but not to sure.
Regards
DRP
Sharing information is the key to a better understanding
Mio M400 WEU, N60I, T1, 2x B2, iCN 510 & lots more
DRP
PostPosted: Sat Jan 21, 2006 11:00 pm    Post subject: Reply with quote
Hi.
Forgot to say I do not think that New maps & old software will work. I think that new software old maps work. Also no mix of both, on same SD card.
DRP
Gee-Pee
PostPosted: Sat Jan 21, 2006 11:19 pm    Post subject: Re: Navman 510 software query!!!! Reply with quote
jnielow wrote:
Hello All,
Thanks again
Jason :D
Answers are, yes the software will work - it is intended to update the older v3. Ii have checked out my local Navman supplier who would normally have the but he says only Navman are currently supplying it. As the the benefits, this forum is full of the members various views on its benefits or otherwise. Suggest you run through the forum for the last two months and have a good read and make up your own mind. Wink
Incidentally although the maps might be dated 2004 I think you will find that they are much older than that as it takes time to the developer to prepare them for SatNav use - could be 3,4,5 years Exclamation
Gee-Pee
Tim Buxton
PostPosted: Sat Jan 21, 2006 11:39 pm    Post subject: Reply with quote
DRP wrote:
Hi.
DRP
I think you are right in the first two beliefs, but I have had V3 and V3.5 maps on the same card. They can't be enabled at the same time, is my experience.
Tim
DRP
PostPosted: Sun Jan 22, 2006 12:23 am    Post subject: Reply with quote
Hi Tim
You are correct, so for myself if I have no mix on the same card I can never get it wrong. So a rule of thumb I never ‘Mix’ maps.
DRP
22.071 (03 Jul 24)
