illusion786 Occasional Visitor
Posted: Thu Jan 19, 2006 11:56 pm Post subject: Medion Micromaxx MDPPC 150 |
Hi Guys, great forum you have lotsa helpful info's.......
I just want to ask if anyone knows how i can get the speed camera database on this Pda.
The dvice is a Medion Micromaxx MDPPC 150
Many thanks |
berghaus Occasional Visitor
Posted: Fri Jan 20, 2006 2:22 pm Post subject: Re: Medion Micromaxx MDPPC 150 |
illusion786 wrote: | Hi Guys, great forum you have lotsa helpful info's.......
Many thanks |
YES DITCH THE MEDION AND PUT TTN5 ON (I DID) LOADES BETTER. _________________ MIO 168 + MICROMAXX MDPPC 150 WITH MEDION FIRMWARE UPGRADE (A MUST FOR TTN5)
TTN5
Memory Map 2004 1:50000 & 1:25000 + AERIAL ALL UK (FANTASTIC)
Mountain Biking (OFF ROAD)
Hiking |
Posted: Sat Jan 21, 2006 12:42 am Post subject: |
Thank you for the reply.
I did put on TTN5 after install it say it canot detect GPs device.
Do you have any idea ho i can fix that?
I did try and install the GPS update but it made no diffrence.
Thank you for any Help |
dabut Regular Visitor
Posted: Sat Jan 21, 2006 1:10 am Post subject: |
my mdppc150 is set on nmea/4800 baud rate/serial cable sp2
and works well hope this helps _________________ ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6 |
Posted: Sat Jan 21, 2006 1:42 am Post subject: |
Thank you for the reply, will test it out and let you know the results....
Much Greatfull for that info...
thanks |
Samninetysix Occasional Visitor
Posted: Sat Jan 21, 2006 12:04 pm Post subject: |
Yes the speed cam database does work on this pda with tt5. It sometimes takes about 10 minutes for it to detect a "gps device" so just leave it on till it does
Oh and hello all |
Posted: Sat Jan 21, 2006 12:46 pm Post subject: |
dabut wrote: | my mdppc150 is set on nmea/4800 baud rate/serial cable sp2
and works well hope this helps |
finally, it works. thank you so much for the settings. |
Posted: Sat Jan 21, 2006 10:13 pm Post subject: |
glad it works for you and thanks for letting me know _________________ ipaq 4150 on powered cradle with tt6
ps73uk Regular Visitor
Posted: Sun Jan 22, 2006 7:20 pm Post subject: |
Have you all got the signal strength being displayed on the micromaxx pda's??, the one i've got here at the moment has now got tomtom 5 on it, it works fine but refuses to display signal strength. _________________ Garmin Streetpilot i3,
Tomtom One
Paul |
lazza Occasional Visitor
Posted: Sun Jan 22, 2006 7:39 pm Post subject: |
I had the same problem, settings worked great :D :D
cheers lazza |
Posted: Mon Jan 23, 2006 12:11 am Post subject: |
ps73uk wrote: | Have you all got the signal strength being displayed on the micromaxx pda's??, the one i've got here at the moment has now got tomtom 5 on it, it works fine but refuses to display signal strength. |
Yeah the signal strengths dont show for some reason. The bars are just empty.
Anyone have a fix for this |
Posted: Mon Jan 23, 2006 12:34 am Post subject: |
illusion have you done the R3 firmware update if so it should show the sat meter _________________ ipaq 4150 on powered cradle with tt6
Posted: Mon Jan 23, 2006 1:06 am Post subject: |
Yeah thanks for the reply, noticed the other post about the fimware. Updated and is working great.
Thanks |
Posted: Mon Jan 23, 2006 2:28 pm Post subject: |
I am a Complete noob, can any tell me how to firmware update the medion mdp150
cheers, lazza |
Posted: Mon Jan 23, 2006 4:40 pm Post subject: |
lazza wrote: | I am a Complete noob, can any tell me how to firmware update the medion mdp150
cheers, lazza |
Download the update. unzip it and the instruction are in there. |
